Quadrature encoder and loop count
Results 1 to 2 of 2
    May 2007
    Republic Serbia
    Default Quadrature encoder and loop count
    After much our spend it work in interrupt's like Henrik suggest me and I am nearly finish.
    Need only one sugget more from peoples here.
    Next problem or maybe not :?
    QEI counter count in circles up/down for example 0-1999 and oposite 1999-0...in 4X mode.
    Now when I am at position 100 for example and command new position - 100 pulses motor will go to 0 and stop - OK but if maybe inertia of shaft move QEI only one step down then here is problem Setpoint is on position 0 value but QEI is 1999!
    I am little confused on how to set relation between Setpoint and QEI register of position ?
    I want to move motor to any direction with PID without limit of numbers of turn to+ or minus.
    Maybe I ned dead zero like minus limit /?
    Any suggest.
    Regards Robert
    May 2007
    Republic Serbia
    Unhappy part of my code...
    Here is QEI module count set to count from 0 - 999 .
    x is number of cyrcle's of QEI module up and down.
    QEI variable is final counter..etc
    loop:
         z = 0
         PosHigh = POSCNTH                           'Get high byte of counter
         PosLow = POSCNTL                            'Get low byte of counter
         PosTemp = POSCNTL                           'Get low byte again
         If PosLow - PosTemp = 0 then Goto Done      'Compare, if equal we're done.
         PosHigh = POSCNTH                           'If not, get values again.
         PosLow = POSCNTL
         z = 1
    Done:
         Position = POSHIGH * 256 + PosLow           'Put high and lowbyte together.
         if position > 1000 then position = 1000
         if position < 1 then position = 0
         h = QEICON.5                                'QEICON.5 for right = 1 for left = 0
         if PIR3.2 = 1 and h =1 then x = x+ 1
         if x <> 0 and PIR3.2 = 1 and h =0 then x = x- 1
         PIR3.2 = 0                                  'PIR3.2 maxcount transition down or up was detected
         h = 0
         QEI =  (1000 * x) + position                    ' increment  total counter
         if z = 1 and h = 0 then QEI = QEI -(1000-position) ' dectement  total counter
         if h = 1 and QEI = 0 then
         QEI = 65535
         if QEI > 65535 then
         x = 0
         QEI = 0
         if porta.0 = 0 then setpoint = setpoint + 1
         if setpoint > 65535 then
         setpoint = 0 and QEI = 0 and x = 0
    Butwhen I count to minus after QEI variable com to 0 if I move shaft of motor more to CCW real QEI conter will continue 999,998 and if my setpoint stay at 0 I am in big problem...
    Any suggest please
    Regards Robert
  1. Quadrature encoder and ASM Interrupts. questions..
    By godfodder in forum mel PIC BASIC Pro
    Last Post: - 17th March 2013, 14:45
  2. Calculate Distance Using Rotary Encoder
    By guanerrr in forum mel PIC BASIC Pro
    Last Post: - 4th May 2012, 16:40
  3. Problem with ASM IRQ using FSR0 on PIC18F252
    By mytekcontrols in forum mel PIC BASIC Pro
    Last Post: - 11th March 2008, 20:48
  4. Slow Opto Encoder With Interrupts
    By crhomberg in forum mel PIC BASIC Pro
    Last Post: - 24th October 2007, 15:04
  5. Encoder problem
    Last Post: - 12th September 2006, 22:21
