Problem compiling EasyHID code
Results 1 to 4 of 4
    Mar 2008
    Default Problem compiling EasyHID code
    Hi.
    I've just installed MPASM, PBP and MicroCode studio, and then I created a EasyHID project.
    But everytime I try to compile the project, it gives med the following errors:
    RES directive cannot reserve odd number of bytes in PIC18 absolute mode
    Error[180] c:\picprojects\usb\usb18mem.asm 116 : RES directive cannot reserve odd number of bytes in PIC18 absolute mode
    Warning[231] c:\picprojects\usb\usb18mem.asm 116 : No memory has been reserved by this instruction
    Error[180] c:\picprojects\usb\usb18mem.asm 117 : RES directive cannot reserve odd number of bytes in PIC18 absolute mode
    Warning[231] c:\picprojects\usb\usb18mem.asm 111 : No memory has been reserved by this instruction
    And so on....
    Anyone who knows what the problem is?
    Best Regards
    Thomas Jespersen
    PBP's old USB files can't be used with the new versions of MPASM.
    The new version of PBP 2.60 has new USB files that will work with it. But if you're trying to compile an older USB program ... you have to make changes to the files being included, and create a new Descriptor, because the one's from EasyHID don't work with 2.60.
    Consequently, until David updates EasyHID, it's "Broke".
    If you go back to an earlier version of MPLAB/MPASM then you can still compile the EasyHID or other old USB programs with PBP 2.50 or previous.
    meLabs has MPLAB 8.15a on their website.
    http://www.melabs.com/support/mplab_old_versions.htm
    Mar 2008
    Downgrading the MPASM solved the problem.
    Steveo2969's Avatar
    Steveo2969 Guest
    HI,
    I'm currently using PBP 2.50c with MPlab 8.15a and MicroCode Studio Plus 3.0.0.5 and I want to upgrade to PBP 2.60 and the latest version of MPlab but i'm wondering if the problem still exsists when trying to compile older USB EasyHID code?
  1. My first DT_INT code has a problem.....
    By E Kizer in forum mel PIC BASIC Pro
    Last Post: - 13th April 2009, 13:37
  2. Weird code problem
    By Navaidstech in forum mel PIC BASIC Pro
    Last Post: - 16th March 2009, 11:16
  3. Making Program Code Space your playground...
  4. problem with my code
    By civicgundam in forum mel PIC BASIC Pro
    Last Post: - 3rd February 2008, 01:52
  5. Servo Code problem
    By ALFRED in forum General
    Last Post: - 2nd March 2006, 03:30
