serial to PIC
Results 1 to 23 of 23
Thread: serial to PIC
    Jul 2009
    Default serial to PIC
    I am picbasic pro user
    I made this program to send serial signal from PIC to PC
    define osc 4
    include "bs2defs.bas"
    key1 var porta.2
    findkey:
    if key1 = 0 then press1
    press1:
    SEROUT PORTa.0,N9600,["KINDOWS 1 "]
    goto findkey
    by this program if I make port a.2 = 0 the program send this [kindows] as a serial signal from port a.0.
    Now I need If I send serial signal from PC to PIC
    If I send this [k] from PC to PIC and then PIC make any port like RA1 high to active a relay.
    Please some one help me soon.
    http://www.picbasic.co.uk/forum/showthread.php?t=561
    Not sure of the PIC you are using...but if it has analog on it the above should help.
    Jul 2009
    So So but I can't find the answer on it
    Default Tesla
    I misread your post before...
     SERIN PORT?.?,N9600,[K],myVar
    IF myVar = 3 THEN gosomeplace or dosomething
    Send K and another value from the PC " K3 " for example.
    The PIC will wait for the "K". When the PIC receives a "K" the next character will be written to myVar.
    Jul 2009
    Hi..
    thank u alot I lik [Always wear safety glasses while programming]
    I forget to tell u I am new in PICBASIC PRO now only 2 weeks. I think the code will be like this:
    define osc 4
    wait:
    SERIN PORTa.1,N9600,["K3"],myVar
    IF myVar = 3 THEN out
    out:
    HIGH PORTb.7
    PAUSE 300
    LOW PORTb.7
    goto wait
    but I cant understand [myvar]. How I can decide it???
    Thank u in advance.
    Jul 2009
    its not working
    May 2008
    Italy
    define osc 4
    wait:
    SERIN PORTa.1,N9600,["K"],myVar
    IF myVar = 51 THEN out ' Ascii 51 = decimal 3 (When you type 3 myvar will be 51)
    goto Wait ' this line is esential otherwise any key will activate the function
    out:
    HIGH PORTb.7
    PAUSE 300
    LOW PORTb.7
    goto wait
    This is the code that Dave suggested.
    From keyboard type K3 to activate portB.7 for 300 millisecs.
    Al.
    Jul 2009
    Now I am using windows hyper terminal to send serial signal. When I am sending [k] from it the terminal send it in ascii or in hex??
    I think send it in Ascii!!!
    so I have to send [k] or [k3]??
    and becuse I am new in PICBASIC PRO I can't understand how I can decide [myvar]
    Can u help ??
    Read the post from Al very carefully. He has everything there you need.
    Not sure what you mean by deciding "myVar". It is just a variable
    to store a value. The serin command will write data to that
    variable and the if/then part checks to see what the value is.
    Oh, the safety glasses thing. It is not a joke.
    Jul 2009
    Do you think this code will working fine??
    define osc 4
    wating:
    SERIN PORTa.1,N9600,["K"],b1
    IF b1 = 51 THEN out ' Ascii 51 = decimal 3 (When you type 3 myvar will be 51)
    goto wating ' this line is esential otherwise any key will activate the function
    out:
    HIGH PORTb.7
    PAUSE 300
    LOW PORTb.7
    goto wating
    I am using PIC16F84a and port RA! Connected to 22k ohm then to the pc serial port. And I am using windows hyper terminal to send the serial signal now my question number tow is what I have to send [k3] or [3] or[k] or 51???
    good glass:)
    Send K3...
    Jul 2009
    Its not working
    PLZ help me
    May 2008
    Italy
    check if your wiring is the same as the attached schematic.
    Al.
    Jul 2009
    Yes it's like your drawing but not working. I send {k3} from the windows terminal and from another 2 programs and it's not working. I am using PICBASIC PRO and PIC16F84a and My code now exactly like this:
    define osc 4
    wating:
    out:
    HIGH PORTb.7
    PAUSE 300
    LOW PORTb.7
    goto watin
    best regard
    kindows
    May 2008
    Italy
    check if hyperterminal settings are OK.
    In my case serial port is # 2, it could be different for your computer. The setting of snap 165 must be the same.
    Al.
    Jul 2009
    Avery thing is same I am using USB converter [USB to serial 232] and I set up it to work in port 8 and I test it with another hardware [ customer LCD] and that is working fine.
    Jul 2009
    plz help me.
    May 2008
    Italy
    I think the problem is with the USB-RS232 converter and the resistor connection to the pic.
    You must use a Max232 to connect pic to your PC with this converter.
    In such a case you must also change your code as follow :
    SERIN PORTa.1,T9600,["K"],b1
    Al.
    Quote Originally Posted by kindows View Post
    wating:
    out:
    HIGH PORTb.7
    PAUSE 300
    LOW PORTb.7
    goto watin
    Your loop label is wrong. watin instead of wating
    Jul 2009
    Default Thanks fo all
    Thanks for all how help me to finalize my project its working fine now. The problem was with output time I make it before 300 only that is not enough to make the LED blinking I make it now 3000 and its working fine now.
    Thanks for all and I hope we can find good idea to be in progress [[ [progress began with an idea]]] and on that time we will wear safety glasses while programming
    I am glad it is working. But.....
    You should be able to see 300 millisecond blink.
    How long does the LED stay on now? Your code says 3 seconds.
    Jul 2009
    Default 3000 milsec = 3 sec
    3 sec.That is fine to make relay work
    but now I have new Question I think u can help [blinking LED]
    best Regard in advance
    KINDOWS
    Try this and see if you see it blink
    blink:
    HIGH PORTb.7
    PAUSE 250
    LOW PORTb.
    PAUSE 250
    GOTO blink
  1. PIC to PIC "wired" serial one-way communication - SERIN2/SEROUT2
    Last Post: - 14th April 2008, 20:02
  2. Automatic VB6 to pic serial connection
    By arniepj in forum Code Examples
    Last Post: - 10th January 2008, 07:57
  3. Serial Com Pic to Pic
    By uludere72 in forum mel PIC BASIC Pro
    Last Post: - 31st May 2005, 10:06
  4. Serial Pic to Pic using HSER
    Last Post: - 11th March 2005, 23:14
  5. Serial communication PIC to PIC help.
    By Rubicon in forum mel PIC BASIC Pro
    Last Post: - 24th January 2005, 15:45
