M E Labs ( the maker of your compiler ) has samples, and I think that is where this one came from as it has zero documentation ( as to ownership ). I suggest you look their site over, many samples there.
' READ and WRITE word variables to on-board EEPROM
' Word is used to add 1000 to each location address and store the
' result. The word data must be stored as 2 separate bytes.
INCLUDE "modedefs.bas" ' Include serial modes
SO VAR PORTC.6 ' Define serial output pin
B1 VAR BYTE ' Address variable
W2 VAR WORD ' Data variable
loop:
For B1 = 0 To 12 step 2 ' Step 2 because each word requires 2 bytes of memory
W2 = B1 + 1000 ' Add 1000 to address
Write B1, W2.HIGHBYTE ' Write high byte of word
Write B1+1, W2.LOWBYTE ' Write low byte of word to next address
Next B1
For B1 = 0 To 12 step 2 ' Step 2 to get word size data
Read B1, W2.HIGHBYTE ' Read high byte
Read B1+1, W2.LOWBYTE ' Read low byte
SerOut SO,T2400,[#W2," ",10,13] ' Display the word data
Next B1
SerOut SO,T2400,[10,13,10,13] ' Skip 2 Lines
GoTo loop ' Forever
you see a for next loop pointing to location in eprom to write or read from.
