	DEFINE OSC 20
Start          var    PortB.0   'Input to start timers
Up1            var    PortB.1   'Up button to change seconds
Down1          var    PortB.2   'Down button to change seconds.
Up01           var    PortB.3   'Up button to change tenths of second.
Down01         var    PortB.4   'Down button to change tenths of second.
Up001          var    PortB.5   'Up button to change hundredths of a second
Down001        var    PortB.6   'Down button to change hundredths of a second
Tool           var    PortB.7   'Button to change to diffent menu
UpStage        var    PortA.0   'Button to change stages
DownStage      var    PortA.1   'Button to change stages
LCD            VAR    PortC.0   'LCD output
StageCounter    var     byte
Stage1OnS       data    word      100
Stage1OffS      data    word      110
Stage2OnS       data    word      200
Stage2OffS      data    word      220
Stage3OnS       data    word      300
Stage3OffS      data    word      330
Stage4OnS       data    word      400
Stage4OffS      data    word      440
Stage5OnS       data    word      500
Stage5OffS      data    word      550
Stage6OnS       data    word      600
Stage6OffS      data    word      660
Stage7OnS       data    word      700
Stage7OffS      data    word      770
Stage8OnS       data    word      800
Stage8OffS      data    word      880
Stage9OnS       data    word      900
Stage9OffS      data    word      990
Stage10OnS      data    word      1000
Stage10OffS     data    word      1010
test            var     word
Stage1On       VAR    word
Stage1Off      VAR    word
Stage2On       VAR    word
Stage2Off      VAR    word
Stage3On       VAR    word
Stage3Off      VAR    word
Stage4On       VAR    word
Stage4Off      VAR    word
Stage5On       VAR    word
Stage5Off      VAR    word
Stage6On       VAR    word
Stage6Off      VAR    word
Stage7On       VAR    word
Stage7Off      VAR    word
Stage8On       VAR    word
Stage8Off      VAR    word
Stage9On       VAR    word
Stage9Off      VAR    word
Stage10On      VAR    word
Stage10Off     VAR    word
Checker        var    byte
CurStage       var    Byte
PreOn          var    Byte
PreOff         var    byte
CurOn          Var    byte
CurOff         var    byte
NxtOff         var    Byte
NxtOn          var    byte
SubStage       var    byte
BL             var    byte
Prefix          con     $FE             ' needed before each command
LcdCls          CON     $51             ' clear LCD (use PAUSE 5 after)
LcdLine1        CON     $00             ' move cursor to line 1
LcdLine2        con     $40             ' move curson to line 2
LcdLine3        con     $14             ' move curson to line 3
lcdLine4        con     $54             ' move curson to line 4
LcdCol1         con     $00             ' move cursor to column 1
LcdCR           CON     $0D             ' move pos 0 of next line
LcdOn           CON     $41             ' LCD on; cursor off, blink off
LcdHome         con     $46
Backlight       con     $53             ' Backlighting 1-8
Contrast        con     $52             ' Contrast 1-50
CursorPS        con     $45             'Cursor Position
CursorOn        con     $47             'Cursof On
CursonOff       con     $48             'Cursor Off
OPTION_REG.7 = 0 'Pull Ups enabled
INTCON.7=0
ADCON0.0 =0
StageCounter = 1
Include "Elapsed.bas"
Include "modedefs.bas"	' Mode definitions for Serout
gosub ClearScreen
'---------Display Start-Up Info-------
Serout LCD, T9600, [Prefix,LcdHome,"xBase Computing",Prefix,CursorPS,LcdLine2,"Timer"]
pause 2000
gosub ClearScreen
Pause 2000
gosub  Read_Data
'------------Sets up backlighting--------------
Repeat
    iF Tool = 0 and UpStage = 0 tHEN
      BL = 8
    iF Tool = 0 and DownStage = 0 tHEN
      BL = 8
    Gosub Change_Stage
    Gosub Change_Time
 until Start = 0
'Repeat    'Transbrake button pushed
'  HDSRPM = 0
'  LDSRPM = 0
'  DSRPMCounter = 0
'Until Start = 1
Gosub StartTimer
Gosub ClearScreen
Serout LCD,T9600,["On"]
gosub StopTimer
Change_Stage:
If UpStage = 0 then
   if StageCounter < 10 then
      StageCounter = StageCounter +1
If DownStage = 0 then
   if StageCounter >1 then
      StageCounter = StageCounter -1
Gosub Set_Display
Change_Time:
If Up1 = 0 then
   Stage1on= Stage1On + 1
Set_Display:
Select Case StageCounter
Case 1
     CurStage = 1
     PreOn = Stage10On
     PreOff =Stage10Off
     CurOn = Stage1On
     CurOff = Stage1Off
     NxtOn = Stage2On
     NxtOff = Stage2Off
     Gosub Display_Stage
Case 2
     CurStage = 2
     PreOn = Stage1On
     PreOff =Stage1Off
     CurOn = Stage2On
     CurOff = Stage2Off
     NxtOn = Stage3On
     NxtOff = Stage3Off
     Gosub Display_Stage
Case 3
     CurStage = 3
     PreOn = Stage2On
     PreOff =Stage2Off
     CurOn = Stage3On
     CurOff = Stage3Off
     NxtOn = Stage4On
     NxtOff = Stage4Off
     Gosub Display_Stage
Case 4
     CurStage = 4
     PreOn = Stage4On
     PreOff =Stage4Off
     CurOn = Stage5On
     CurOff = Stage5Off
     NxtOn = Stage6On
     NxtOff = Stage6Off
     Gosub Display_Stage
Case 5
     CurStage = 5
     PreOn = Stage4On
     PreOff =Stage4Off
     CurOn = Stage5On
     CurOff = Stage5Off
     NxtOn = Stage6On
     NxtOff = Stage6Off
     Gosub Display_Stage
Case 6
     CurStage = 6
     PreOn = Stage5On
     PreOff =Stage5Off
     CurOn = Stage6On
     CurOff = Stage6Off
     NxtOn = Stage7On
     NxtOff = Stage7Off
     Gosub Display_Stage
Case 7
     CurStage = 7
     PreOn = Stage6On
     PreOff =Stage6Off
     CurOn = Stage7On
     CurOff = Stage7Off
     NxtOn = Stage8On
     NxtOff = Stage8Off
     Gosub Display_Stage
Case 8
     CurStage = 8
     PreOn = Stage7On
     PreOff =Stage7Off
     CurOn = Stage8On
     CurOff = Stage8Off
     NxtOn = Stage9On
     NxtOff = Stage9Off
     Gosub Display_Stage
Case 9
     CurStage = 9
     PreOn = Stage8On
     PreOff =Stage8Off
     CurOn = Stage9On
     CurOff = Stage9Off
     NxtOn = Stage10On
     NxtOff = Stage10Off
     Gosub Display_Stage
Case 10
     CurStage = 10
     PreOn = Stage9On
     PreOff =Stage9Off
     CurOn = Stage10On
     CurOff = Stage10Off
     NxtOn = Stage1On
     NxtOff = Stage1Off
     Gosub Display_Stage
end select
Display_Stage:
Case 1
   gosub FirstLine
   Serout LCD,T9600,[Prefix,$45,LcdLine2, "10    ", #test,"   ", #PreOff, Prefix,$45,LcdLine3,"1     ", #CurOn, "  " , #CurOff, "   ON", Prefix,$45,LcdLine4, "2     ", #NxtOn, "  ", #NxtOff]
   pause 5000
Case 2
   gosub FirstLine
   Serout LCD,T9600,[Prefix,LcdLine2, "10", #PreOn," ", #PreOff, Prefix,LcdLine3, "1 ", #CurOn, " " , #CurOff, "OFF",Prefix,LcdLine4, "2 ", #NxtOn, " ", #NxtOff]
end select
ClearScreen:
  Serout LCD, T9600, [Prefix,LcdCLS]
  pause 5
SetBackLight:
  Serout LCD, T9600, [Prefix,Backlight,BL]
  pause 5
FirstLine:
  Serout LCD, T9600, [Prefix,LcdHome,"Stage On   Off"]
Read_Data:
Read 0, Stage1On.LowByte
REad 1, Stage1On.HighByte
Read 2, Stage1Off.LowByte
REad 3, Stage1Off.HighByte
Read 4, Stage2On.LowByte
REad 5, Stage2On.HighByte
Read 6, Stage2Off.LowByte
REad 7, Stage2Off.HighByte
Read 8, Stage3On.LowByte
REad 9, Stage3On.HighByte
Read 10, Stage3Off.LowByte
REad 11, Stage3Off.HighByte
Read 12, Stage4On.LowByte
REad 13, Stage4On.HighByte
Read 14, Stage4Off.LowByte
REad 15, Stage4Off.HighByte
Read 16, Stage5On.LowByte
REad 17, Stage5On.HighByte
Read 18, Stage5Off.LowByte
REad 19, Stage5Off.HighByte
Read 20, Stage6On.LowByte
REad 21, Stage6On.HighByte
Read 22, Stage6Off.LowByte
REad 23, Stage6Off.HighByte
Read 24, Stage7On.LowByte
REad 25, Stage7On.HighByte
Read 26, Stage7Off.LowByte
REad 27, Stage7Off.HighByte
Read 28, Stage8On.LowByte
REad 29, Stage8On.HighByte
Read 30, Stage8Off.LowByte
REad 31, Stage8Off.HighByte
Read 32, Stage9On.LowByte
REad 33, Stage9On.HighByte
Read 34, Stage9Off.LowByte
REad 35, Stage9Off.HighByte
Read 36, Stage10On.LowByte
REad 37, Stage10On.HighByte
Read 38, Stage10Off.LowByte
REad 39, Stage10Off.HighByte
