Noise on PORTC.0 with PIC16F73
Results 1 to 8 of 8
    May 2007
    Default Noise on PORTC.0 with PIC16F73
    Hi All
    I am using a PIC16F73 and I am trying to pulse PORTC.0, PORTC.1 and PORTC.2
    I have set these ports as outputs using TRISC = %11111000
    However, when I measure the signal on the pins, the pulse for PORTC.1 and PORTC.2 is clean, but the signal for PORTC.0 is very dirty, i.e. lots of noise?
    How can I get rid of this noise on PORTC.0?
    Thank you in advance for any help!
    Here is all my code:
    DEFINE OSC 20
    DEFINE LCD_DREG PORTB
    DEFINE LCD_DBIT 0
    DEFINE LCD_RSREG PORTA
    DEFINE LCD_RSBIT 4
    DEFINE LCD_EREG PORTC
    DEFINE LCD_EBIT 3
    DEFINE LCD_BITS 4
    DEFINE LCD_LINES 2
    DEFINE LCD_COMMANDUS 2000
    DEFINE LCD_DATAUS 50
    DEFINE NO_CLRWDT 1 ' Don't insert CLRWDTs
    TRISC = %11111000 ' Set RC0, RC1, RC2 to output, rest is input
    loop:
    PORTC.0 = 1
    PORTC.1 = 1
    PORTC.2 = 1
    PORTC.0 = 0
    PORTC.1 = 0
    PORTC.2 = 0
    Goto loop
    May 2007
    I forgot to say:
    The noise on PORTC.0 is present during the off pulse
    May 2007
    After reading another thread I added
    LOW PORTC.0
    just before the loop and this seemed to solve my problem!
    Why would that be?
    Isn't TRISC %11111000 supposed to set PORTC.0 as an output?
    Quote Originally Posted by passion1 View Post
    LOW PORTC.0
    Why would that be?
    Hello Passion1,
    Yes TRISC <font color=red><b>=</b></font color>%11111000 will set RC0 as an output
    LOW PORTC.0 is a RMW operation and the data sheet advises not to do this on portC of this chip. RC.0 shares TMR1clockin and osc functions so you want to disable those if using as a standard I/O so:
    T1CON.0 = 0 'disable timer 1
    CCP1CON=0 ' disable capture compare module which works with timer 1
    Datasheet SEC. 4.3
    "Since the TRIS bit override is in effect while peripheral is enabled, read-modify-write instructions (BSF, BCF, XORWF) with TRISC as destination should be avoided."
    May 2007
    Joe
    Thank you!
    I used
    and that solved my problem completely!
    I have some doubt about it... @POR, Timer1 is already off, CCP as well.
    What you experiment is indeed an RMW issue. You don't want to write to successive output bit by bit, this will cause some problem one day or another, and faster your OSC is, more chance you have to see it happen.
    What you want to do is to write to the WHOLE PORT at once instead of single bits.
    Here:
    PORTC=7
    PORTC=0
    Goto Here
    Use shadow register, modify it, then dump it to your specific PORT, that's my suggestion.
    Question
    Hi, Passion
    What Kind of load do you have on portC.0 ???
    Here, your signal might not be far from ... ~ 700 kHz ( at first sight ! 555 Khz ... at second sight )
    Here:
    PORTC=7
    PORTC=0
    Goto Here
    PortC value on POR,BOR xxxx xxxx
    value on all other resets uuuu uuuu
    PortC Data direction Register
    value on all resets 1111 1111
    My theroy is T1 osc was causing his noise.
  1. Pretty Sure a Noise Problem
    By Tobias in forum General
    Last Post: - 10th December 2009, 00:46
  2. Loud Noise at 20khz
    By koossa in forum Off Topic
    Last Post: - 14th July 2009, 09:24
  3. Need suggestions for noise suppression
    By paul.barsamian in forum General
    Last Post: - 29th March 2008, 14:37
  4. Getting rid of noise of car battery/alternator
    By passion1 in forum mel PIC BASIC Pro
    Last Post: - 9th March 2008, 05:11
  5. (Off Topic) Noise from battery supply
    By CLARE in forum mel PIC BASIC Pro
    Last Post: - 22nd August 2004, 10:01
