Cordic trig assembly code for PIC18f - Page 2
Page 2 of 2 FirstFirst 12
Results 41 to 55 of 55
  1. #41
    Apr 2010
    Gavle, Sweden
    Default Re: Cordic trig assembly code for PIC18f
    The problem is solved. I found another version of trig.inc in post 13, and it works well for me. I have to put the word variables x,y into long variables before doing any calculations on them.
  2. #42
    Quote Originally Posted by B-O Eliasson View Post
    That's a good bare bones cordic version as long as you don't mind manipulating the radians. So you could either use that and do math to your liking, or you could use TrigL , which you can find with my tilt example here: http://www.picbasic.co.uk/forum/cont...-axis-g-sensor . If you use TrigL.inc, you would probably want to add a line to replace goto main with goto overcordic
    and at the end of the TrigL.inc add a line overcordic:
    Keep us posted, I'd love to see your project.
    Walter
  3. #43
    Oct 2008
    Hi Walter, I have been looking at this for some time now and keep coming back to this post. I am actually attempting to do a similar project to the tilt sensor project which you have built only on a single axis. I believe I am almost there now and just need a few pointers! I am looking at your code atn2. the following is the equation i require to solve: tan-1 ((zresult - calval)/SQR ((5017 - calval)^2 - (zresult - calval)^2))
    Now from reading your posts would I be right in thinking that if i do the following:
    x=0
     y= ((zresult - calval)/SQR ((5017 - calval)^2 - (zresult - calval)^2))
    call atn2
    Am I right in thinking that this would convert my equation as I am not interested in the hyp or does the x vaule come into play?
  4. #44
    Hi Chris,
    Well, I might have to admit that the cordic may not be the best solution for a single axis tilt sensor. It is a natural for a dual or triple axis sensor. If you just have a single axis sensor, I might suggest a lookup table. Now I'm not really good at converting mathematical equations back and forth, so I can't say for sure if you are on the right track with the one you have. It doesn't resemble the ones I have used enough for me to tell. But I can show you some that I think would work. And, perhaps yours would work too. I just can't tell from here.
    Here is the app note I worked with before. As you can see, the arctan equation "theta = arctan(Ax/Az)" on page 4 is a pretty cool thing. Of course, this one requires a two axis sensor, but it keeps resolution up to about 1.3 degrees. It also fits in pretty well with are atan2 cordic.
    Attachment 4533
    Now for a single axis sensor, your resolution at near 90 degree angles goes down to about 9 degree accuracy. This seems to lend itself better to just a lookup table. But, if you really wanted to use the cordic, you could.
    For a single axis sensor, one equation for determining angle is arcsin (x) where x is acceleration in g's . Our cordic, can't do arcsin, but it can do arctan. We can use the following equation from Wikipedia:
    and solve for theta.
    atan(y) = atan2(y,1)
    But, in our case, we are feeding y with a value which at its peak, = 1g. So, whatever value your sensor gives for 1g, you should fill in for the "1" value. y will equal 2 arctan x/((1+sqr(1-x^2)) , then run it through the cordic. I just feel if its going to be off by up to 9 degrees (because we are using a single sensor) why not just use a lookup table.
    http://www.scalerobotics.com
  5. #45
    Jul 2011
    Hawaii
    I am using your TRIG.inc in a small program. The values appear correct from (ang) = 0 to 9000, 0 to 90.00 degrees. For values, 9000 < (ang) < 18000 ,the
    values for x and y appear to switch. As an example with an (ang) value of 8900 or 89.00 degrees I receive a value back x = 29995 and y = 525. This seems correct.
    For an (ang) value of 9100 or 91.00 degrees I receive back x = -523 and y = 29995. For 91.00 degrees I would expect x = 29995 and y = -523 ?
    - Martin
  6. #46
    Thanks Martin,
    I'll take a look at it tonight. It should be easy enough to switch them around. With the pic16 solution, you have to work in quadrants. So that's probably where my error is.
  7. #47
    I think I found my error in sincos. I had 36000 where 27000 now is. This did not compensate for the 90 degree shift for radians. Let me know if this works better.
    sincos:
        'use angle as deg.dd for example 35999 is 359.99 degrees
        if ang < 9001 then ang = 9000 - ang              'change degrees to radians
        if ang > 9000 then ang = 27000 - (36000 - ang)   'change degrees to radians
        ang = ang * 466
        ang = div32 256
        asm
            call sin_cos
        endasm
  8. #48
    Jul 2011
    Hawaii
    This is getting closer. The magnitude and sign values for the sin(ang) are all good. The magnitude term for the cos(ang) is good except the sign ,msb is incorrect for quadrants 2,3 and 4. Here is a list of what I get FOR ang = 0 to 350 STEP 1000 ;
    ang = 0 sin(ang) = 5 cos(ang) = 30000
    ang = 1000 sin(ang) = 5209 cos(ang) = 29544
    ang = 2000 sin(ang) = 10266 cos(ang) = 28188
    ang = 3000 sin(ang) = 15004 cos(ang) = 25981
    ang = 4000 sin(ang) = 19287 cos(ang) = 22981
    ang = 5000 sin(ang) = 22983 cos(ang) = 19285
    ang = 6000 sin(ang) = 25983 cos(ang) = 14998
    ang = 7000 sin(ang) = 28188 cos(ang) = 10264
    ang = 8000 sin(ang) = 29544 cos(ang) = 5207
    ang = 9000 sin(ang) = 30000 cos(ang) = 3
    ang = 10000 sin(ang) = 29544 cos(ang) = 5207
    ang = 11000 sin(ang) = 28188 cos(ang) = 10264
    ang = 12000 sin(ang) = 25983 cos(ang) = 14998
    ang = 13000 sin(ang) = 22983 cos(ang) = 19285
    ang = 14000 sin(ang) = 19287 cos(ang) = 22981
    ang = 15000 sin(ang) = 15004 cos(ang) = 25981
    ang = 16000 sin(ang) = 10266 cos(ang) = 28188
    ang = 17000 sin(ang) = 5209 cos(ang) = 29544
    ang = 18000 sin(ang) = 5 cos(ang) = 30000
    ang = 19000 sin(ang) = -5207 cos(ang) = 29544
    ang = 20000 sin(ang) = -10260 cos(ang) = 28190
    ang = 21000 sin(ang) = -14998 cos(ang) = 25983
    ang = 22000 sin(ang) = -19283 cos(ang) = 22985
    ang = 23000 sin(ang) = -22981 cos(ang) = 19287
    ang = 24000 sin(ang) = -25981 cos(ang) = 15004
    ang = 25000 sin(ang) = -28188 cos(ang) = 10266
    ang = 26000 sin(ang) = -29544 cos(ang) = 5213
    ang = 27000 sin(ang) = -30000 cos(ang) = 5
    ang = 28000 sin(ang) = -29549 cos(ang) = -5195
    ang = 29000 sin(ang) = -28199 cos(ang) = -10258
    ang = 30000 sin(ang) = -25986 cos(ang) = -14992
    ang = 31000 sin(ang) = -22987 cos(ang) = -19275
    ang = 32000 sin(ang) = -19296 cos(ang) = -22976
    ang = 33000 sin(ang) = -15013 cos(ang) = -25977
    ang = 34000 sin(ang) = -10271 cos(ang) = -28184
    ang = 35000 sin(ang) = -5216 cos(ang) = -29544
    - Martin
  9. #49
    Hmmm,
    Well, I can't test it from here, but this seems like it might work. (If not, I will think harder and do some testing). Thanks for the feedback Martin.
    sincos:
        if ang > 9000 then ang = 45000 - ang            'change degrees to crazy radians
        ang = ang * 466
        ang = div32 256
     asm
            call sin_cos
    endasm
  10. #50
    Jul 2011
    Hawaii
    Walter,
    I added three lines as shown in red. With the additions all 4 quadrants are returning correct magnitude and sign values.
    See attached test file.
    - Martin
    i var byte BANK0
    j Var byte BANK0
    quad var byte BANK0
    x var word bank0
    y var word bank0
    ang var word bank0
    ang_temp var word bank0
    dy var word bank0
    dx var word bank0
    atans var word[15] bank0
    atans(0) = 16384
    atans(1) = 9672
    atans(2) = 5110
    atans(3) = 2594
    atans(4) = 1302
    atans(5) = 652
    atans(6) = 326
    atans(7) = 163
    atans(8) = 81
    atans(9) = 41
    atans(10) = 20
    atans(11) = 10
    atans(12) = 5
    atans(13) = 3
    atans(14) = 1
    goto overcordic
    atan2:
    asm
    call atan2_sqrt
    endasm
    'convert to degrees.dd y is degrees
    If ang < 16384 then y = 16383 - ang
    if ang > 16383 then
    y = 65535 - ang
    y = y + 16383 'correct 90 degrees for radian
    y = y * 256 'divides radians to get degrees within 57ppm
    y = div32 466 'degrees.dd is y, radians is ang
    sincos:
    ang_temp = ang ' Store ang.
    ang = ang * 466
    ang = div32 256TRIG.basTrig_example.bas
    asm
    call sin_cos
    endasm
    if ang_temp > 9000 then y = ~y + 1 ' Perform 2's complement of y if ang > 90 for cos(ang).
    asm
    ; Calculates the sine and cosine of the given angle
    sin_cos:
  11. #51
    Thanks Martin,
    That works! But there is a little less math in post 49. It makes the rest of the cordic do what its supposed to for the rest of the quadrants. Thanks for pointing it out.
    Here is TRIG.inc V1.5
  12. #52
    Walter,
    Thank you for your original work and the update.
    Martin, thanks for bringing up again.
    I was trying to make this work last year. My results were similar to Martin's.
    Assuming it was something in my code. I had to settle for pbp ATN.
    Can't wait to try it out
    Best regards
  13. #53
    Jul 2011
    Hawaii
    Walter,,
    Yes the statement: IF ang > 9000 then ang = 45000 - ang, does the job. For some reason the first time I tried using it the results were crazy so I simply tried to make a patch. I must have typed in something incorrectly. Excellent job Walter ! Thanks for this piece of code.
    73's de Martin
  14. #54
    Jul 2011
    hi ScaleRobotics , i am interested in your codes posted on #51. and i have a problem.
    ang=3000
    call sincos
    x=60395, y=39551
    for all ang values i get same numbers, i dont understan what is the problem? thank you
  15. #55
    That's weird. Maybe you can show us some of your code?
  1. How much code space do PBP statements use.
    Last Post: - 13th February 2009, 21:31
  2. Loop with two motor and 2 sensors
  3. Making Program Code Space your playground...
  4. 4 Chanel Dmx512 ready assembly code to PBP ?
    By syscoder in forum mel PIC BASIC Pro
    Last Post: - 21st March 2007, 23:55
  5. Your Suggestions: Assembly code material?
    By dw_picbasic in forum General
    Last Post: - 2nd February 2007, 17:33
