Glcd help
Results 1 to 3 of 3
Thread: Glcd help
    Feb 2005
    Default Glcd help
    i found on microbasic compiler one tool that convert image to data.the tool name is glcd bitmap editor.I convert one bitmap but i can't print it to screen. I start print the first data on top left to write and top to down.does anybody played before with bitmaps to tell me an idea?
    one sample code is here:
    ' Set Addr Ptr
    glcd_msb = $10
    glcd_lsb = $00
    glcd_cmd = ADDR_PTR_SET
    gosub send_2
    gl_y= $1000 'start picture and print the first 248 bytes
    gl_ad1= gl_y.BYTE1
    gl_ad2= gl_y.BYTE0
    gosub pict_part1 'print part1 248 bytes
    gosub pict_part2 'print part2 onother 248 bytes
    pict_part2:
    for gl_i=0 to 239
    lookup gl_i,[0, 0, 0, 0, 0, 0, 0, 0,_
    1,255,255,255,255,255,255,247,_
    252, 0, 0, 0, 0, 0, 0, 0,_
    0, 0, 0, 0, 0, 0,126, 0,_
    0, 0, 0, 0, 7,224, 0,224,_
    0, 0, 0, 15,128, 0, 0, 0,_
    0, 0, 59, 0, 0, 8, 0, 0,_
    0, 0, 0, 0, 0, 0, 0, 0],gl_k
    glcd_msb=gl_k
    glcd_cmd=DATA_WR_INC
    gosub send_1
    next
    send_2:
    gosub busy_chk
    glcd_dat = glcd_lsb
    glcd_cd = 0
    glcd_rd = 1
    glcd_WR = 0
    glcd_CE = 0
    pauseus GL_PAUSE
    glcd_wr = 1
    glcd_ce = 1
    send_1:
    gosub busy_chk
    glcd_dat = glcd_msb
    glcd_cd = 0
    glcd_rd = 1
    glcd_WR = 0
    glcd_CE = 0
    pauseus GL_PAUSE
    glcd_wr = 1
    glcd_ce = 1
    send_cmd:
    gosub busy_chk
    glcd_dat = glcd_cmd
    glcd_rd = 1
    GLCD_CD = 1
    glcd_WR = 0
    glcd_CE = 0
    pauseus GL_PAUSE
    glcd_wr = 1
    glcd_ce = 1
    Feb 2005
    i found how to display an image. i download a programm called fastlcd and this program gives an output in basic but with different format so i built a program that convert it to our code. The code to display the image is from workbench.below i have a sample code to see how you can display an image with t6963c lcd controller.because i did the program fast you have to delete the "," and "_"before the ] and also to fix the bytes to the last part of image.if you have any questions please feel free to ask.
    Default Great
    Hi, finally got some compilable code, well i compilete the code using pbp and tried simulating it on PIC SIMULATOR IDE but i can't get any output...can you provide me with the schematic of the example too...
    Best Regards
    Quote Originally Posted by santamaria View Post
  1. A Serial GLCD 128x64 Simple Project
    By Oldspring in forum Off Topic
    Last Post: - 8th March 2010, 20:58
  2. glcd display vs lcd display
    By davids in forum mel PIC BASIC Pro
    Last Post: - 3rd July 2009, 18:16
  3. PBP Glcd
    By RICHARD.C in forum mel PIC BASIC Pro
    Last Post: - 13th June 2008, 02:21
  4. GLCD and TouchScreen trouble
    By SteveB in forum Off Topic
    Last Post: - 13th June 2007, 14:11
  5. How to put valiable to GLCD
    By pramarn in forum mel PIC BASIC Pro
    Last Post: - 13th October 2006, 16:18
