Please help with code for DS18B20 - Page 2
Page 2 of 3 FirstFirst 123 LastLast
Results 41 to 80 of 110
  1. #41
    Dec 2008
    Ploiesti, ROMANIA
    In my test I measure :
    - MINUS 15.20 ' C in the refrigerator
    - PLUS 24.15 ' C in the room.
    With one sensor and with two sensor too.
  2. #42
    When I tried for that and with one sensor, it shows -0.06 Celsius. and the sensor would not respond for variation
    Some ( wrong ! ) values have a typical meaning :
    0.06 as a "measure " shows a connecting ( or sensor ) problem ... Check your DQ line ...
    85 shows conversion not completed ...
  3. #43
    Mar 2006
    Hyderabad (India)
    Quote Originally Posted by fratello View Post
    Can you upload the .bas file that you have used please !!
    Sarma
  4. #44
    Dec 2008
    Ploiesti, ROMANIA
    See post #35. Renamethe file .txt as .bas.
  5. #45
    Mar 2006
    Hyderabad (India)
    Thanks Fratello !!
    Sarma
  6. #46
    May 2008
    Hi, Fratello
    I played a bit with your program ... Elektor won't be anymore what it was ... -cries-
    Note you'll have to comment the Easypic5/16F877A section and uncomment the Elektor section.
    This way you will be able to use the 18B20 in any resolution you like ...
    And OVERALL do not ask a +/- 0.5°C precision sensor to give 1/100° C .... !!!
    I've been playing with this all day today and it's a great piece of code.
    I used this as I have an easypic 6*
    I have one problem/question that perhaps someone could answer please
    When I program the pic, the sisplay shows * at the end of the 1st line even when no buttons are or have been pressed, I thought the * was only to show a button had been pressed?
    Also if I cycle through the button presses, ie set temp and set hysteresis they both work fine
    however when I press the button again to show the actual temp that also works. but it never seems to update UNLESS I hold the button in, then it updates continually
    I've been trying to get it to update at a regular interval or any interval but it just wont, am I doing something wrong or does it never update the temp?
  7. #47
    Wink Check Hardware !
    That looks no pullups - or a Pulldown ! - on PORTA.0 input ... the " * " only appears when Porta.0 is tied to ground.
    Everything fine here ...
  8. #48
    May 2008
    I thought that might be the problem, but where would I put
    high portA.0
    If I put it before the mainloop it displays the temperature all the time,
    if I put it at the end of mainloop then it still displays the * and stays on set temperature.
    I can't figure out where to put it, must be easy but I just cant see it.
  9. #49
    Wink
    Quote Originally Posted by lew247 View Post
    high portA.0
    May be you could place The pullup resistorS ( 3 x 47-100k ) between Porta.0,1 and 2 and VCC ...
    No need to place it inside the Pic ... that won't work !
  10. #50
    May 2008
    Sorry Alain, I wasn't too clear on what I meant.
    The easypic board HAS pullup resistors on those ports.
    When i run the program, the lcd sits there with just the * displaying even when no button has been pressed (portA.0 in this circuit/program)
    it does nothing else.
    When I press portA.0 the display cycles through set temp (which I can set properly with portA.1 and portA.2)
    Next press brings it to the Hysteresis which again will set ptoperly
    the 3rd press brings up the temperature display mode (mode 0 )
    It displays the temperature at the moment the button is pressed but it never updates or checks again.
    I have checked it works by holding down the button on portA.0 and if held down (LOW) then the display works properly, measuring the temperature continious, and if the temp changes it makes port C.0 or C.2 high depending on the set temp and hysteresis.
    My problem is I cannot get it to continually measure temperatre without holding down portA.0
    Also when I turn the power on first all I get is the LCD blank other than * being displayed.
    Having read the code, * should only display after each button press, but it always displays.
    Also I'd like it when power is turned on to measure and show the temperature continoiusly until the button (portA.0) is pressed.
    Hope that made more sense, as I knew I couldn't put resistors inside the pic
  11. #51
    malc-c's Avatar
    malc-c Guest
    Very informative thread and funny enough something that I was hoping to work on myself as I'm looking at replacing the simple on/off thermostats that control the heating in my reptiles vivariums.
    Can someone (Alain?) post up a schematic for the project. (or settings for the EasyPIC5) - I'm looking at trying to develop this a bit further so the output is pulsed, with the mark / space ratio reducing as the set point is neared. I've used commercial on/off stats, and the temperatures are hard to control. The idea is to keep the hot spot fairly constant and below 35C max, as constant exposure to a surface above this temperature can cause a burn risk to snakes.
    With the thermometer probe placed on the shelf near the logger (it wasn't actually touching the same spot), and with the thermostats sensor in the cool part of the shelf, the thermostat was set so the digital thermometer read a max of 34C. Here's are the results - the bit you are interested in is between 18:00 hrs onwards
    Obviously the heat was conducting through the wood, which cooled slower than if the sensor was measuring air or the surface of the heater. But you can see that there is a large temperature swing between the min and max readings, and that the surface reached over 40C
    To reduce this difference I placed the two probes next to the logger directly above the heater. Here is the results, which still show the same cycling, but with a lower differential (average 5 degree C), but is more stable
    The pulse proportional stat reduces the cycling as it's not switching the heater on/off/on, it maintains a steady temperature by pulsing power to it thus the heater never cools.
    I could purchase a couple of commercial PP stats for around £100 (possibly less via mail order) but then where's the fun in that Now I know there are a lot of you experience programmers that have dabbled with PWM, so wonder if you would like to add your comments here.
  12. #52
    malc-c's Avatar
    malc-c Guest
    In the set up below I used a commercial data logger to record the surface temp of the shelf over a 24 hr period.
    Although I had originally posted this in my post above, the forum software said I had more than 4 images ????
  13. #53
    Malcolm,
    Sounds like the perfect job for a PID loop.
    Angry
    Hi, Lew
    You have a HARDWARE misconfig somwhere on your board ...
    the program AT THE MOMENT, is running aboard my EasyPic5 ...
    Check pullup jumpers on Porta.0,1,and 2 : UP
    check buttons jumper : GND
    Nothing more nothing less ...
  15. #55
    Wink
    Hi, Malc
    Do you understand the "why" of the Parallax document, now ... ???
    You'll have to place your Button Key INSIDE the vivarium ( hé,hé ... WITH the snakes !!! ) if you want a true image of your temp.
    The graphs you've shown can't be used to finely trim a regulator ... but are a good example.
    Temp measurement and moreover probes placing is a real art ... to get a nice temp regulation.
    But let's begin by the beginning :
    ALL you have to do already is in ZE Book ... with relevant code.
    We'll see details later ...
    Till then, I'll implement the PID Regulator on my existing " 84 " Thermostat ( not the one shown here, but a nicer one which is pin for pin compatible !! )
  16. #56
    May 2008
    You were right as always. I hadn't the board configured properly.
    I totally forgot about the row of jumpers to set the pins pull-up or pull-down, I had it set wrong.
    Thank you
  17. #57
    malc-c's Avatar
    malc-c Guest
    Hi, Malc
    Agreed,
    I've just taken a further reading with the probes 2" from the heater, so its sampling the air temperature. Here's the result (the button logger still on the shelf as shown)
    If you ignore the fluctuations in between 10pm and 3am when the snake was out and obviously laying on the sensor, and look at the period 4am to 4pm you'll see it a lot more stable and only has a 0.2C deviation.
    DT, could you elaborate on a PID loop.
    Alain, could you provide a link to that file... I'm frantically searching for a DS1820 so I can start developing this project, but as my PBP programming is so rusty (and basic) may need you guys to offer some assistance if I get stuck (or should that be when I get stuck )
  18. #58
    malc-c's Avatar
    malc-c Guest
    Quote Originally Posted by malc-c View Post
    OK - google was my friend
    http://en.wikipedia.org/wiki/PID_controller
  19. #59
    malc-c's Avatar
    malc-c Guest
    Err.... yeah...
    previous_error = 0
    integral = 0
    start:
    error = setpoint - actual_position
    integral = integral + (error*dt)
    derivative = (error - previous_error)/dt
    output = (Kp*error) + (Ki*integral) + (Kd*derivative)
    previous_error = error
    wait(dt)
    goto start
    LOL - £34 for a commercial thermostat looks more promising !
  20. #60
    You've got better friends than that.
    HenrikOlsson for instance ...
    PID-filter routine (2nd try).
    http://www.picbasic.co.uk/forum/showthread.php?t=5874
    I've used it. It works great.
    It's a little tricky to find the correct constants. But trial and error usually works.
    Although there is a purposeful method to tune the loop.
    malc-c's Avatar
    malc-c Guest
    Sorry Darrel.... it's been a long day......!
  22. #62
    Mar 2006
    Hyderabad (India)
    when the same is compiled and loaded, it just behaves as i reported earlier a frozen value of 0.06
    no variation
    But luckily it is working for you perhaps. May i expect a hex file for 16F628A please?
    Sarma
  23. #63
    Mar 2006
    Hyderabad (India)
    Fratello's code has definite mistakes, and need attention. With the mistakes How it was working for him is a wonder.The suspected line numbers, i shall be indicating for consideration / possible correction.
    I suspect that the code posted by him at #35 is not what he might be using.
    Sarma
  24. #64
    Default ???
    Hi, Sarma
    What are you talking about ???
    Fratello's code can of course bear some little improvements but WORKS FINE !!!
    ( I just translated it to a 16F877A aboard an Easy Pic 5 ... and it's nice.)
    PS: do not tell me you are waiting for custom code or you do not have something personnal working since the 8th of April ... please ...
  25. #65
    Err.... yeah...
    What ? That's as clear as mud! I thought they taught you that in primary school.
    34 pounds for a thermostat? Must be the VAT ! Damn Globalists, want to federalize the world !
    http://www.prothermostats.com/produc...product=100934
    $40 US 24.42 GBP
  26. #66
    Oct 2010
    Default Re: Please help with code for DS18B20
    hi all,
    i would like to make the circuit for the thermostat. could you please upload the circuit schematic? thanks a lot for your help.
  27. #67
    Oct 2010
    Dear all,
    sorry for asking you for the schematic, i did it from the code but i need your advice according to the second sensor please.
    could you please help me out to finish the schematic?
    thanks.
  28. #68
    Oct 2010
    i have been trying to simulate the circuit on the proteus and also trying to make it work on the test board.
    On the simulation i have some result but on the test board i dont get anything on the lcd.
    Unfortunately with the code from Elektor i get some results on the lcd on the test board. But very wrong result like 234 oC.
    Could someone upload the hex file from Mr. Fratello's #35? Could anyone made it work?
  29. #69
    Oct 2009
    Utah, USA
    The second sensor (and the third, forth, fifth, etc, etc.) simply goes in parallel with the first... see example below.
    The PIC's job is to address each individual sensor to read its value. That is how the One-Wire bus works. Each sensor has an address and will only respond to it's address.
    Dwight
  30. #70
    Dec 2008
    Ploiesti, ROMANIA
    Yes. right !!! In my code I put the individual code of each sensor . For working with ANOTHER sensors, first you need to read the address of each sensor and then modify the code. You can find some examples on this forum...
  31. #71
    Oct 2010
    hello,
    thanks for the answer. i use the DS18B20, so i dont need to do any modification.
    The problem is that i cannot see anything on the display. It looks like something is really wrong inside the code.
    I think that i make the mistake on the code or the circuit above.
    1) does this schematic corresponds to the code? (i need to put one more sensor)
    2) do i need to do anything inside the code
    for example in the following lines do i need to chose one of these?
    ;DS18B20_9bit CON %00011111 ; 93.75ms, 0.5°C
    ;DS18B20_10bit CON %00111111 ; 187.5ms, 0.25°C
    ;DS18B20_11bit CON %01011111 ; 375ms, 0.125°C
    ;DS18B20_12bit CON %01111111 ; 750ms, 0.0625°C (default)
    DS18B20_1_12bit CON %01111111 ; 750ms, 0.0625°C
    ;DS18B20_2_12bit CON %01111111 ; 750ms, 0.0625°C
    But still i dont see anything on my lcd.
  32. #72
    Oct 2010
    To be more specific,
    as i understand i need to find the unique ID from each sensor and then modify it on the code.
    First i need to solve an other problem, what about i dont see anything on the display?
    Shouldnt i see some 'no sensor' or like that at least?
  33. #73
    Dec 2008
    Ploiesti, ROMANIA
    Yes, it's right what you say in post #71 !
    Put this in top of code :
    @ DEVICE pic16F628A, intOSC_osc_noclkout, WDT_OFF, PWRT_OFF, BOD_OFF, MCLR_ON
    define osc 4
    REMOVE Xtal and caps (no need quartz precision) ; or keep it - but then replace "Intosc_osc_noclkout" with "XT_Osc".
    Now you MUST have something on display !
  34. #74
    Oct 2010
    i've tried it but nothing on the lcd again,
    i think it has to do with the osc commands and there is the problem.
    i put a 4mhz ceramic with two legs, i idid also tried the ceramic 4mhz with 3 legs. Nothing on the screen.
    i'm sad that cannot complete it.
    thanks a lot for your help! am i doing something wrong with the schematic? Do i need anything else?
    The code from the elektor works, but i dont have the ds1820. And it is on the screen xxx.xx
    But i dont understand why it does not work with your code.
  35. #75
    Aug 2010
    Maryland, USA
    First you need to prove the pic is running. There are no caps shown in above schematic at the xtal, do you have caps on it? Have you made a led blink? Did you try internal osc?
    From the quick skim I did on this thread, it seems I have read several posts claiming the code works. Time to look at your hardware.
    -Bert
  36. #76
    Oct 2010
    ok i will try later this afternoon to blink an led.
    Do i need capacitors for the ceramic 4 mhz resonator? I have also used a ceramic with 2 legs resonator at 4 mhz.
    In any case i will try to blink an led.
    As i mentioned on my previous posts, i have tried also the code from elektor, and works. (i just dont have the right sensor DS1820 which is very old and i dont get the right results. but i have something in the screen at least.
    With the code from Mr. Fratello, i dont have anything on the screen. That mean that there is something wrong, either with the hardware or software.
    Thank a lot again for your help.
  37. #77
    Dec 2008
    Ploiesti, ROMANIA
    The software it's ok !!! Remove the X-tal (leave pins 15 & 16 free), re-compile the code with added from post #73, check the RV1, check the connection to LCD., check the voltage (5 volts).
  38. #78
    Oct 2010
    ok thanks a lot fratello,
    please give me some time to do it in the afternoon.
    I have done something else with a completed different thermostat.
    please check for my from an other thermostat with an old ds1621, a friend of mine gave it me i can upload the code if you like. (really sorry for my Greeks at the video, i upload it for the AVCLUB.gr there is a sub forum for flashlights)
    The reason i put the video is to see the menu for the thermostat configuration. It is nice to see the configured temp and the real time temp at the same time.
    Please check the video at 2:12 for the configuration menu.
  39. #79
    Oct 2010
    there is something on the display now.
    thanks a lot. The problem now is that i dont have the right value for the temp.
    It appears a minus value for both INT and EXT sensor.
    also the values for the SET POINTs are only in minus values. I think the minus symbol appears on both 75 and -25. I will upload pictures later on.
    The values now i have are
    INT: -0.06
    EXT: -0.06
  40. #80
    Dec 2008
    Ploiesti, ROMANIA
    See post #42 !
  1. Reading in Manchester code
    By brid0030 in forum Code Examples
    Last Post: - 10th March 2009, 21:55
  2. How much code space do PBP statements use.
    Last Post: - 13th February 2009, 21:31
  5. Re-Writing IF-THEN-AND-ENDIF code?
    Last Post: - 18th August 2006, 17:23
