Please help with code for DS18B20
Results 1 to 40 of 110
    Dec 2008
    Ploiesti, ROMANIA
    Default Please help with code for DS18B20
    I made the great project of "Digital thermostat (080090-11)" from Elektor july_august 2008 ; unfortunate I do not have DS1820 but DS18B20. The temperature show on display is like "xxx.xx 'C" !.
    I read this : "In order to convert the HEX code to a temperature value, first you need to identify if you are using a DS18S20, or DS18B20 series sensor. The code to read the temperature needs to be slightly different for the DS18B20 (and DS1822), because it returns a 12-bit temperature value (0.0625 deg precision), while the DS18S20 and DS1820 return 9-bit values (0.5 deg precision)".
    I try millions different routines, but the result is verry bad...because of this section, I think :
    "DisplayTemp:
    If V >= 10000 then ' Above 0 C.
    Temperature=V-10000
    Else
    Temperature=10000-V ' Below 0 C.
    EndIf
    LcdOut $FE, $C0, Sign, DEC (Temperature / 100), ".", DEC2 Temperature, " ",223,"C "
    Return"
    All the codes I try change the Temperature set and Hysteresis, and the display show the temperature (ex. 24.56'C) , but useless function of thermostat...(Set temperature = 2000.00 and Hysteresis = 200.00).
    And the temperature is different (+24.67 'C) by other device (DS18B20 + PIC 12F675 + LCD Nokia = 23.1'C ; LM35DZ + mV = 23.1 'C)
    It is possible to increase the accuracy of this thermometer/thermostat ?
    Can somebody help me to modify the source for using DS18B20 ?
    Thanks in advance !
    Wink
    Hi, Fratello
    I played a bit with your program ... Elektor won't be anymore what it was ... -cries-
    Note you'll have to comment the Easypic5/16F877A section and uncomment the Elektor section.
    This way you will be able to use the 18B20 in any resolution you like ...
    And OVERALL do not ask a +/- 0.5°C precision sensor to give 1/100° C .... !!!
    Dec 2008
    Ploiesti, ROMANIA
    THANK YOU VERRY MUCH !!!! You make me happy ! I will try the code and I will keep You informed. Thanks again !
    ****** A HAPPY NEW YEAR !!!! ******
    ******* TO ALL !!!! *******
    LE : Now is great, even still remain the 1°C difference...but "OVERALL do not ask a +/- 0.5°C precision sensor to give 1/100° C .... !!!".
    Thanks again !
    B.t.w : what can I use instead of DS18B20 for more accurate measurement ?
    Talking The Horrible truth ...
    Quote Originally Posted by fratello View Post
    Hi, Fratello
    I had a look to all the sensors you can find on the market ...
    The best "out of the box" accuracy ( all including ) will be roughly +/- 0.5 °C ... don't be sad !!!
    going further needs multipoint CALIBRATION ... with some really expensive devices.
    Note linearity is "not so bad" in our measuring range ... so, with a two points calibration ( 0 and 100°C ) , you can reach +/- 0.1 °C without too much pain.
    And remember ... DS18x20 in continuous measurement mode like here, without being fixed on a heatsink, has a 1°C self heating value ... ( a look at the Datasheet will confirm !!! )
    Just have a look to the values displayed from the power up ...
    You missed some Alain.
    We have Industrial Sensors that directly return 16-bit Temperature to two Decimal Places (in the range 0.00C-100.00C).
    It is however a complete waste of time... just breathing in the vicinity, or even just walking nearby create air-currents which wildly change the readings - we just end up ignoring the last digit. If you're trying to distill some moonshine for the New Year festivities, you're not really bothered in monitoring the temperature to hundredths of a degree.
    Wink
    Hi, Mel
    Happy to read from you !!!
    Of course, those sensors exist ... ( you have forgotten to give us the price ... lol ), but are totally out of our Hobbiysts galaxy ...
    Have a Happy new Year
    Mar 2006
    Hyderabad (India)
    Hi, Fratello
    But DS18B20 is capable of giving a better resolution??
    Sarma
    Its resolution (its step in other words) is 0.0625 but its accuracy is +/-0.5C
    May 2008
    Hi, Fratello
    I've been playing with this all day today and it's a great piece of code.
    I used this as I have an easypic 6*
    I have one problem/question that perhaps someone could answer please
    When I program the pic, the sisplay shows * at the end of the 1st line even when no buttons are or have been pressed, I thought the * was only to show a button had been pressed?
    Also if I cycle through the button presses, ie set temp and set hysteresis they both work fine
    however when I press the button again to show the actual temp that also works. but it never seems to update UNLESS I hold the button in, then it updates continually
    I've been trying to get it to update at a regular interval or any interval but it just wont, am I doing something wrong or does it never update the temp?
    Wink Check Hardware !
    That looks no pullups - or a Pulldown ! - on PORTA.0 input ... the " * " only appears when Porta.0 is tied to ground.
    Everything fine here ...
    May 2008
    I thought that might be the problem, but where would I put
    high portA.0
    If I put it before the mainloop it displays the temperature all the time,
    if I put it at the end of mainloop then it still displays the * and stays on set temperature.
    I can't figure out where to put it, must be easy but I just cant see it.
    Wink
    Quote Originally Posted by lew247 View Post
    high portA.0
    May be you could place The pullup resistorS ( 3 x 47-100k ) between Porta.0,1 and 2 and VCC ...
    No need to place it inside the Pic ... that won't work !
  1. Reading in Manchester code
    By brid0030 in forum Code Examples
    Last Post: - 10th March 2009, 21:55
  2. How much code space do PBP statements use.
    Last Post: - 13th February 2009, 21:31
  5. Re-Writing IF-THEN-AND-ENDIF code?
    Last Post: - 18th August 2006, 17:23
