Mesuring current with pic
Results 1 to 14 of 14
    Jun 2008
    Red face Mesuring current with pic
    I found this circuit to measure current with a pic, it seems like a good circuit that will work, using adcin reading the voltage at the high point of the 0.1 ohm resistor. Hence knowing the voltage and the resistance you can calculate the current that is all fine and dandy, my only concern is that @ 12 v running trough a 0.1 ohm a 5 w resistor would no be at all sufficient. I would need a big heat sink and even then is there something i am not seeing, or is the circuit wrong.
    May 2008
    Italy
    You have a lamp of 50 W in series with the resistor of 0.1 ohm 5 W.
    50W/12V=4.2 A this is the current that flow through the resistor.
    4.2 * 4.2 * 0.1 = 1.74 W is the power dissipated by the resistor 5 W is more than dimensioned.
    Al.
    Jun 2008
    Smile Reading current with pic
    That makes lots of sense but what will happen when the 50 w bulb is off, they only load then will be the 0.1 ohm resistor. The power will be over 5 w and burn the resistor out.
    If the bulb is off then the circuit is broken. No current to flow.
    May 2007
    Never mind. Was not thinking straight.
    Sep 2005
    Campbell, CA
    In most cases, the best way to measure current is with a Hall-effect sensor. No voltage loss, no heat, perfect isolation. Check out the Allegro devices.
    http://www.allegromicro.com/en/Produ...rentsensor.asp
    Charles Linquist
    Jul 2005
    Selangor, Malaysia
    Maybe a low ohmic resistor 0.01ohm 5W is suitable in the application.
    The hall effect sensor normally is very expensive in my country.
    Let say the total amp flows is 15A,:
    Voltage dropped = 15 X 0.01 = 0.15V
    Wattage dissipated = 15 X 0.15 = 2.25W
    I have been using this with the volt meter to measure the voltage up to 22A, and it is working fine. The heat will not be a issue for the resistor. But it is a bit expensive.
    May 2008
    Italy
    You mean 15x15x0.15=33.75W
    Al.
    May 2007
    P = I*V = 15 x .15 = 2.25W
    Default p=
    or,
    p=1^2 R
    15X15X.01=2.25
    May 2007
    or V*V/R
    0.15*0.15/0.01 = 2.25W
    Somebody needs a new Calculator.
    <OBJECT CLASSID="clsid:D27CDB6E-AE6D-11cf-96B8-444553540000" CODEBASE="http://download.macromedia.com/pub/shockwave/cabs/flash/swflash.cab#version=6,0,40,0" WIDTH="600" HEIGHT="350" ><PARAM NAME="MOVIE" VALUE="http://www.pbpgroup.com/files/CurrentSense.swf"><PARAM NAME="PLAY" VALUE="true"><PARAM NAME="LOOP" VALUE="true"><PARAM NAME="QUALITY" VALUE="high"><EMBED SRC="http://www.pbpgroup.com/files/CurrentSense.swf" WIDTH="600" HEIGHT="350" PLAY="true" LOOP="true" WMODE="opaque" QUALITY="high" TYPE="application/x-shockwave-flash" PLUGINSPAGE="http://www.macromedia.com/go/getflashplayer"></EMBED></OBJECT>
    Change R1 to 0.01 ohm, and see what happens.
    Note the output voltage to the PIC.
    Default power calc
    Mr DT,
    what a neat utility that is !!
    you can see all the relations between R's, V's, W's etc.
    How about lessons on creating that type of object ?
    don
    amgen
    Thanks Don!
    I'm still looking for those lessons myself.
    Been trying to learn Flash for over a year now, and it's still feels like I'm struggling.
    Maybe another year of practice will help.
  1. Reducing PIC current to as low as possible...
    By FromTheCockpit in forum mel PIC BASIC Pro
    Last Post: - 18th November 2009, 04:28
  2. PIC conducting signal current when off
    By Viberer in forum Off Topic
    Last Post: - 28th May 2009, 17:27
  3. PIC Controlled Current Source
    By Andy Wood in forum mel PIC BASIC Pro
    Last Post: - 30th June 2007, 18:15
  4. Replies: 22
    Last Post: - 9th April 2007, 15:25
