With the 16F628, you have two choices,
1. using the hardware USART with HSERIN/HSEROUT with the following schematic (Courtesy of Bruce)
2. Using any other bit banged solution like DEBUG/SEROUT/SEROUT2 without the MAX232, but only with a single resistor in serie (1.5K is fine) and set the Inverted Mode
For the 12F675, well, one choice... option 2 above.
Do a search here and you'll find tons of example.
