Supported compiler with Proteus VSM; true Windows 7 64 bit compatibility
In my opinion two features that would really improve the productivity of using the PBP compiler would be:
1) Making it one of the supported compilers that would work with Proteus VSM schematic capture and simulation tools;
2) Making the PBP compiler truly compatible with Windows 7 64 bit computers....I have not yet been able to get my PBP 2.6 compiler to work with Windows 7 on my 64 bit machine.
3) In the interest of an integrated solution, ensure that an integrated package of PBP, MSAM, FineLine, and MPLAB will all work as a more integrated combintation on Windows 7 64 bit machines.
Re: Supported compiler with Proteus VSM; true Windows 7 64 bit compatibility
1) PicBasic Pro works great with Proteus. I use it almost every day.
2) PicBasic Pro works great with Windows 7-64, that's the OS I use (at work).
3) PicBasic Pro and MPLAB work great on Windows 7-64.
Is there a specific problem you are having?
Darrel Taylor
I use MCSPlus as editor, PICBASIC PRO 2.6C as compiler, MPASM as assembler and PICKIT2 as programmer. Programs compile OK on WIN7-64 machine but I can't seem to get them to assemble/program. Any suggestions?
Darrel Taylor
I use MCSPlus editor, PBPro 2.6c compiler, MPASM assembler, and PICKIT2 programmer. I don't use MPLAB. My programs that were developed on WINXP compile OK on WIN7-64, but they don'e seem to assemble or program on WIN7-64. Any suggestions?
Try running the Setup Utility on this page ...It has an effect on MCS too.
Close MCS and MPLAB before running.
http://melabs.com/support/mplab.htm
Make sure your MPLAB installation is current. (even though you don't use the MPLAB IDE)
http://www.microchip.com/stellent/id...&part=SW007002
Other than that, please be more specific about what errors you are encountering.
Darrel Taylor
This helped me get it all working under WIN7-64bit. Thanks so much, Darrel!
Looking at MPLAB IDE (which I have never used) caused me to wonder if there is an equivalent to MPLAB SIM that works with PBPRO source code?? I notice from the WEBINAIR at Microchip that MPLAB SIM works with C source code, but no indication of whether you can also use it with PBPRO or not??
JE
Yes you can use it with PBP. No problem at all.
