Vishay 2x16 OLED Display (aka Winstar WEO001602B)
The Vishay OLED-016O002B is a 2x16 compact (53mm x 20mm) OLED display that uses the OLED-0012 controller. The OLED-0012 is substantially different from the OLED-0010 controller (used in most other Vishay OLED displays) that closely resembles the HD44780 controller. The OLED-0012 controller is somewhat like the US2066 controller (used in many Newhaven OLED displays) in that it has an expanded set of commands that are arranged in hierarchical groups (and can be difficult to navigate). This Vishay display is a rebranded Winstar WEO001602B display (available from AliExpress for about $8.00 plus shipping), and is available in blue and yellow.
While the spec sheets indicate the display works in parallel (4-bit and 8-bit), SPI and I2C, the I2C capability is not present in the version I acquired about a year ago through a U.S. distributor. However, the SPI interface works effectively and fit into my project application. There are 0 ohm jumpers on the display's PCB that set the interface configuration for parallel (8080/6800) or SPI, and the SPI jumper configuration is noted in the header in the code sample provided below, along with the pin-out connections.
Also as noted in the code sample header, the OLED-0012 controller seems susceptible to internal register reset problems on power up. The display's 16 pin connector includes a hardware reset on pin 16 that can be used to reset the display independently of the application's power cycling.
'* Name : OLED_016002.PBP *
'* Author : Roberts *
'* Notice : *
'* Date : 10/10/2021 *
'* Version : 1.0 *
'* Notes : PBP code snippet that sends characters to LCD *
'* : via I2C interface (LCD = Vishay 2x16 OLED *
'* : character display with Winstar WS0012 Controller *
' Name : OLED_016002.pbp
' Compiler : PICBASIC PRO Compiler PBPX 3.1.1.4
' Assembler : MicroCode Studio V_5.0.0.5
' Target PIC : PIC16F18346 on Microchip Curiosity Board
' Hardware : Vishay 016O002B OLED display
' Oscillator : 16MHz internal
' Description : PICBASIC PRO program to demonstrate SPI interface to display
' This program demonstrates the OLED initialization sequence and writing text & numbers to a Vishay 2x16 OLED display
' having a Winstar WS-0012 Controller via its SPI interface option. Command and data writes to the WS-0012 controller
' require 10-bit arguments. Commands are expressing as 16-bit constants that are truncated to 10-bits in the SHIFTOUT
' commands, while data characters are 8-bit quantities OR'd with 16-bit write commands and then truncated to 10-bits.
' Because the WS-0012 controller requires 10-bit command and data, direct ASCII writes without the ARRAYWRITE command
' (as is possible with the US2066 controller) is not possible. All displayed characters must be put into an array and
' then written in 10-bit lengths in order to include the RS and R/W bits.
' The arrays hold displayed characters and must be cleared using the subroutine CLEAR_ARRAYS so that vestiges of prior
' displayed lines are erased (the clear display command 0x0001 doesn't accomplish this).
' The WS-0012 controller seems to be sometimes plagued with an inability to clear all of its internal registers upon
' power up and/or initialization. Pin 16 is an active low reset (having an onboard pullup resistor) that can be used
' following power up and can be connected to a microcontroller pin or to a power supervisor IC to ensure resetting.
' The display has 0 ohm shorting resistors on its circuit board that are used to set the interface type that can be
' 8-bit or 4-bit parallel (either 6800 mode or 8080 mode), or SPI mode. For SPI mode, the following jumper settings
' apply:
' JCS - shorted
' L_CS_H - open
' H_SP_L - high
' H_86_L - low
' Wiring connections for SPI mode are the following:
' Pin 1 - Power Ground
' Pin 2 - +5 VDC
' Pins 3-11 - Ground
' Pin 12 - SPI_CK (clock)
' Pin 13 - SPI_DA (out/MISO)
' Pin 14 - SPI_DA (in/MOSI)
' Pin 15 - CS (chip select - active low)
' Pin 16 - Reset (active low)
'************************************* Configure and initialize the target device *************************************
INCLUDE "PIC16F18346_Initialize_Curiosity_Board.PBP" 'Setup for PIC16F18346 on Curiosity Board (Oscillator = 16MHz)
'******************* Alter the following I/O port pin configurations per target application requirements **************
ANSELA = 000000 ' PortA all digital / available pins are A0 through A5 (6 I/O's)
TRISA = 000000 ' PortA all used pins are outputs
SPI_DA VAR LATA.5 'SPI clock pin to 2x16 OLED display (use latch addressing to avoid read/modify/write error)
SPI_CK VAR LATA.4 'SPI data pin to 2x16 OLED display
CS VAR LATA.2
OLED_ARRAY1 VAR BYTE[16] 'This array holds the 16 characters to display on OLED line 1
OLED_ARRAY2 VAR BYTE[16] 'This array holds the 16 characters to display on OLED line 2
temp VAR BYTE 'temp is the variable used to SHIFTOUT the array contents to the OLED
j VAR BYTE 'loop counter
CS = 1 'initialize CS as logic high
D CON 12345 'D is a 5-digit random value constant
H CON $1FA7 'H is a 4-hexit random value constant
'***************************** 'Initialization sequence for the WS-0012 Controller (2x16 OLED) *************************
PAUSE 500 'Controller needs 500mS to stabilize power
CS = 0 : SHIFTOUT SPI_DA, SPI_CK, 5, [$0028\10] : CS = 1 'Function Set - D/L=0, N=2, Default Font
PAUSE 1
CS = 0 : SHIFTOUT SPI_DA, SPI_CK, 5, [$0013\10] : CS = 1 'Character Mode / Power OFF
PAUSE 1
CS = 0 : SHIFTOUT SPI_DA, SPI_CK, 5, [$0003\10] : CS = 1 'Enter Command Set #2
PAUSE 1
CS = 0 : SHIFTOUT SPI_DA, SPI_CK, 5, [$0029\10] : CS = 1 'Power ON
PAUSE 1
CS = 0 : SHIFTOUT SPI_DA, SPI_CK, 5, [$0068\10] : CS = 1 'BVR - Set brightness (0x0060 is max / 0x006F is min)
PAUSE 1
CS = 0 : SHIFTOUT SPI_DA, SPI_CK, 5, [$0000\10] : CS = 1 'Exit Command Set #2
PAUSE 1
CS = 0 : SHIFTOUT SPI_DA, SPI_CK, 5, [$0001\10] : CS = 1 'Clear Display
PAUSE 10
CS = 0 : SHIFTOUT SPI_DA, SPI_CK, 5, [$0016\10] : CS = 1 'Display Direction
PAUSE 1
CS = 0 : SHIFTOUT SPI_DA, SPI_CK, 5, [$0006\10] : CS = 1 'Entry Mode Set
PAUSE 1
CS = 0 : SHIFTOUT SPI_DA, SPI_CK, 5, [$000C\10] : CS = 1 'Display ON
PAUSE 1
CS = 0 : SHIFTOUT SPI_DA, SPI_CK, 5, [$0002\10] : CS = 1 'Home - Start at Line 1 / Position 1
'********************************************* Main Program ************************************************************
' Text displays are filled with 16 characters so that intermediate clear display commands aren't needed
ARRAYWRITE OLED_ARRAY1,["VISHAY 2x16 OLED"] '2x16 OLED Program Announcement
GOSUB OLEDOUT1
ARRAYWRITE OLED_ARRAY2,[" DISPLAY DEMO "]
GOSUB OLEDOUT2
PAUSE 2000 'Hold display for 2 seconds
ARRAYWRITE OLED_ARRAY1,["Winstar WS-0012 "] 'Controller Announcement
GOSUB OLEDOUT1
ARRAYWRITE OLED_ARRAY2,["OLED Controller "]
GOSUB OLEDOUT2
' Now display numerical values:
gosub CLEAR_ARRAYS 'Clear array data of prior displayed text characters
ARRAYWRITE OLED_ARRAY1, [DEC D] 'display the decimal constant 12345 (converts value to ASCII text)
GOSUB OLEDOUT1
ARRAYWRITE OLED_ARRAY2, [HEX H] 'display the hexadecimal constant 0x1FA7
GOSUB OLEDOUT2
PAUSE 2000
goto main 'Loop forever
'************************************* 2x16 OLED Display Subroutine ****************************************************
'This subroutine in universal output for Line 1
OLEDOUT1:
CS = 0 : SHIFTOUT SPI_DA, SPI_CK, 5, [$0080\10] : CS = 1 'Start at Line 1 / Position 1
PAUSE 1
For j = 0 to 15
temp = OLED_ARRAY1[j] 'SHIFTOUT doesn't support array arguments
CS = 0 : SHIFTOUT SPI_DA, SPI_CK, 5, [$0200 | temp\10] : CS = 1 'this creates 10-bit write data commands
Next j
'This subroutine in universal output for Line 2
OLEDOUT2:
CS = 0 : SHIFTOUT SPI_DA, SPI_CK, 5, [$00C0\10] : CS = 1 'Start at Line 2 / Position 1
PAUSE 1
For j = 0 to 15
temp = OLED_ARRAY2[j] 'SHIFTOUT doesn't support array arguments
Next j
'Clear both arrays of previously displayed characters
CLEAR_ARRAYS:
For j = 0 to 15 'clear the array using space characters
OLED_ARRAY1[j] = " " 'does not require SHIFTOUT to display
OLED_ARRAY2[j] = " "
next j
'**************************************** Program End ******************************************************************
