hello
can someone help me as I use these modules rf
http://www.ebay.com/itm/Perfect-2Mbp...item35bee9e1e1
to communicate between 2 PIC16F628A
thank
hello
thank
What is the question / problem?
:) please give more info on what your are seeking to do , want from the pic and RF module ,
But i would start out by saying the following
1. pic chips you are looking to use don't support an inbuilt spi bus , so shiftin / shiftout command structure is to be used to get the command to the RF module
2. depending what your final use is for the pics, consideration of what other functions it may have to do ,You may look at 16F1825 for a good price, given it better mem/ cpu flexibility
3. do a search on my other posts relating to the rf module , you will find some good details and structure refs
4. i found connecting the IRQ pin on the module to be handy , but not a requirement
5. cos the module works at 3.3V not 5v, you may wish to look at using the pic at 3.3v , with a regulator , consider the osc speed , standby voltage , wakeup requirements of the module - depending on the app / pic requirements/ PIC programming at 3.3v
6. depending on your requirements , consider a another RF modual that would require a serial stream of data only to be sent / recieved as an alternative to this module, this options depends on how critical the data sent / received is / retry requirements/ voltage etc , note that there are also alot of devices that use 2.4ghz
7. only look at the NRF24L01+ versions, these are often with a zig zag pattern on the aerial not the one you have linked to
have a look at http://www.ebay.com.au/itm/2-PCS-NRF...item35bc3877e9
I have found that the range on the plus version to be better.
I hope that some of the questions raised help you to define what your seeking from what the rf module is to do
Sheldon
hello Sheldon
thank you
esperencia not have much in this type of modules
I'll buy other modules
thank you very much
a hug
After receiving those two from Ebay, I started programming a routine.
This is a working two way communication routine:
'* Name : nRFLarge.BAS *
'* Author : SCUMARI Tec *
'* Notice : Copyright (c) 2013 SCUMARI Group *
'* : All Rights Reserved *
'* Date : 1-6-2013 *
'* Version : 1.0 *
'* Notes : PIC18LF13K50 controller for the NRF24L01+ RF module *
'* : This is standard software for both sender and receiver. *
'* : Both module start in receive mode. When the button is pressed,*
'* : a byte is randomized ans send over by two bytes. Both recei- *
'* : ver and sender displays the value on a LED bar. *
' PIC18LF13K50
' ___ ___
' VDD O|1 - 20|O VSS
' RA5 OSC1 OSCIN O|2 19|O RA0 + PGD
' RA4 AN3 OSC2 CLKOUT O|3 18|O RA1 D- PGC
' RA3 MCLR VPP O|4 17|O VUSB
' RC5 CCP P1A T0CKI O|5 16|O RC0 AN4 C12IN+ INT0 VREF+
' RC4 P1B C12OUT SRQ O|6 15|O RC1 AN5 C12IN1- INT1 VREF-
' RC3 AN7 P1C C12IN3- PGM O|7 14|O RC2 AN6 P1D C12IN2- CVREF INT2
' RC6 AN8 SS T13CKI T1OSCI O|8 13|O RB4 AN10 SDI SDA
' RC7 AN9 SDO T1OSCO O|9 12|O RB5 AN11 RX DT
' RB7 TX CK O|10 11|O RB6 SCK SCL
'18F14K50
@ __CONFIG _CONFIG1L, 000h
@ __CONFIG _CONFIG1H, 018h
@ __CONFIG _CONFIG2L, 000h
@ __CONFIG _CONFIG2H, 000h
@ __CONFIG _CONFIG3H, 080h ;080h is MCLRE
@ __CONFIG _CONFIG4L, 000h
@ __CONFIG _CONFIG5L, 003h
@ __CONFIG _CONFIG5H, 0C0h
@ __CONFIG _CONFIG6L, 003h
@ __CONFIG _CONFIG6H, 0E0h
@ __CONFIG _CONFIG7L, 003h
@ __CONFIG _CONFIG7H, 040h
INCLUDE "modedefs.bas"
DEFINE OSC 16
DEFINE SHIFT_PAUSEUS 100
OSCCON = 118 '4550 op $FE / K50 op 118 / 689 op 112
OSCTUNE = 31 '4550 op $0F / K50 op 31 / 689 op 15
ADCON0 = 0
ANSEL = 0
ANSELH = 0
UCON = 0
IOCA = 3
IOCB = 0
INTCON = 0
PORTA = 0
TRISA = %00111111
PORTB = 0
TRISB = 0
PORTC = 0
TRISC = 0
sck VAR PORTB.4
miso VAR PORTA.4
irq VAR PORTA.1
mosi VAR PORTB.5
scn VAR PORTB.6
ce vAR PORTB.7
butt var PORTA.0
addr var byte
addr1 var byte
addr2 var byte
addr3 var byte
addr4 var byte
addr5 var byte
addrm var word
temp VAR word
tmp VAR BYTE
indatl VAR BYTE
indath VAR BYTE
outdatl VAR BYTE
outdath VAR BYTE
i VAR BYTE
pype var byte
cnt var byte
'Times
tlong con 100
tmid con 50
tshort con 25
scn = 1
sck = 0
ce = 0
PORTC = 129
pause 50
PORTC = 66
pause 50
PORTC = 36
pause 50
PORTC = 24
pause 50
PORTC = 24
pause 50
PORTC = 36
pause 50
PORTC = 66
pause 50
PORTC = 129
pause 50
PORTC = 0
indatl = 0
init:
addr = %11100010 : gosub ComWrite 'Flush RX
addr = %11100001 : gosub ComWrite 'Flush TX
addr = 32 + 7 : outdatl = %01000000: gosub ConfWrite 'Clear RX_DR, TX_DS and MAX_RT
'Set PWR_UP to 1 (00.1)
'MASK_RX_DR = 0 (00.6)
'MASK_TX_DS = 1 (00.5)
'MASK_MAX_RT = 1 (00.4)
'Set PRIM_RX to 1 for receive (00.0)
addr = 32 + 1 : outdatl = %00000001 : gosub ConfWrite 'ENAA_Px
addr = 32 + 2 : outdatl = %00000001 : gosub ConfWrite 'ERX_Px
addr = 32 + 5 : outdatl = 40 : gosub ConfWrite 'RF_CH
addr = 32 + 6 : outdatl = $0F : gosub ConfWrite 'RF_SETUP
addr = 32 + 17 : outdatl = 2 : gosub ConfWrite 'RX_PW_P0
addr1 = $E1: addr2 = $E2: addr3 = $E3: addr4 = $E4: addr5 = $E5
addr = 32 + 10 : gosub ADDRWrite 'RX_ADDR_P0
'addr1 = $E1: addr2 = $E2: addr3 = $E3: addr4 = $E4: addr5 = $E5
'addr = 32 + 11 : gosub ADDRWrite
'outdatl = $E1
'addr = 32 + 15 : gosub ConfWrite
addr = 32 + 16 : gosub ADDRWrite 'TX_ADDR
' 'Read back config
' for i = 0 to 9
' PORTC = i
' pause 500
' addr = i : gosub statRead
' PORTC = indatl
' pause 1000
''init2:
'' if butt = 1 then init2
' next i
' addr = 10 : gosub AddrRead
' PORTC = addr1
' pause 500
' PORTC = addr2
' pause 500
' PORTC = addr3
' pause 500
' PORTC = addr4
' pause 500
' PORTC = addr5
' pause 500
' addr = 16 : gosub AddrRead
' PORTC = addr1
' pause 500
' PORTC = addr2
' pause 500
' PORTC = addr3
' pause 500
' PORTC = addr4
' pause 500
' PORTC = addr5
' pause 500
' 'goto init
addr = 32 : outdatl = %00111111 : gosub ConfWrite 'Start receiving
'Set CE to 1
ce = 1
pauseus 200
if butt = 0 then gosub Transmit
if irq = 0 then gosub Receive
Transmit:
ce = 0
addr = 32 : outdatl = %00111110 : gosub ConfWrite 'PRIM_RX = 0
random temp
PORTC = temp : outdatl = temp : outdath = temp
addr = %10100000 : gosub DataWrite 'send TX_PLD
pauseus 100
Trans0:
ce = 1
PAUSEUS 200
ce = 0
Trans1:
addr = 7 : gosub statRead
if indatl.4 = 0 then Trans2 'Read MAX_RT
addr = 32 + 7: outdatl = %00100000: gosub ConfWrite 'Clear MAX_RT
goto trans0
Trans2:
if indatl.5 = 0 then Trans1 'Read TX_DS
addr = 32 + 7: outdatl = %00100000: gosub ConfWrite 'Clear TX_DS
addr = 32 : outdatl = %00111111: gosub ConfWrite 'Set PRIM_RX to 1
ce = 1
Receive:
ce = 0
addr = %01100001 : gosub DataRead
PORTC = indath
pause 200
PORTC = indatl
addr = 32 + 7: outdatl = %01000000: gosub ConfWrite 'Clear RX_DR
ce = 1
ComWrite:
scn = 0
pauseus tshort
for tmp = 0 to 7
mosi = addr.7
pauseus tshort
sck = 1
pauseus tmid
sck = 0
pauseus tmid
addr = addr << 1
next tmp
scn = 1
ConfWrite:
scn = 0
pauseus tshort
for tmp = 0 to 7
mosi = addr.7
pauseus tshort
sck = 1
pauseus tmid
sck = 0
pauseus tmid
addr = addr << 1
next tmp
for tmp = 0 to 7
mosi = outdatl.7
pauseus tshort
sck = 1
pauseus tmid
sck = 0
outdatl = outdatl << 1
pauseus tmid
next tmp
' SHIFTOUT mosi, sck, 1,[addr]
' SHIFTOUT mosi, sck, 1,[outdatl]
' pauseus tshort
scn = 1
StatRead:
scn = 0
pauseus tshort
for tmp = 0 to 7
mosi = addr.7
pauseus tshort
sck = 1
pauseus tmid
sck = 0
pauseus tmid
addr = addr << 1
next tmp
pauseus tshort
indatl = 0
for tmp = 0 to 7
indatl = indatl << 1
sck = 1
pauseus tmid
indatl = indatl + miso
sck = 0
pauseus tmid
next tmp
pauseus tshort
' SHIFTOUT miso, sck, 1,[indatl]
' pauseus tshort
scn = 1
AddrWrite:
scn = 0
pauseus tshort
for tmp = 0 to 7
mosi = addr.7
pauseus tshort
sck = 1
pauseus tmid
sck = 0
pauseus tmid
addr = addr << 1
next tmp
for tmp = 0 to 7
mosi = addr1.7
pauseus tshort
sck = 1
pauseus tmid
sck = 0
addr1 = addr1 << 1
pauseus tmid
next tmp
for tmp = 0 to 7
mosi = addr2.7
pauseus tshort
sck = 1
pauseus tmid
sck = 0
addr2 = addr2 << 1
pauseus tmid
next tmp
for tmp = 0 to 7
mosi = addr3.7
pauseus tshort
sck = 1
pauseus tmid
sck = 0
addr3 = addr3 << 1
pauseus tmid
next tmp
for tmp = 0 to 7
mosi = addr4.7
pauseus tshort
sck = 1
pauseus tmid
sck = 0
addr4 = addr4 << 1
pauseus tmid
next tmp
for tmp = 0 to 7
mosi = addr5.7
pauseus tshort
sck = 1
pauseus tmid
sck = 0
addr5 = addr5 << 1
pauseus tmid
next tmp
' pauseus tshort
scn = 1
AddrRead:
scn = 0
pauseus tshort
for tmp = 0 to 7
mosi = addr.7
pauseus tshort
sck = 1
pauseus tmid
sck = 0
pauseus tmid
addr = addr << 1
next tmp
pauseus tshort
addr1 = 0
for tmp = 0 to 7
addr1 = addr1 << 1
sck = 1
pauseus tmid
addr1 = addr1 + miso
sck = 0
pauseus tmid
next tmp
pauseus tshort
addr2 = 0
for tmp = 0 to 7
addr2 = addr2 << 1
sck = 1
pauseus tmid
addr2 = addr2 + miso
sck = 0
pauseus tmid
next tmp
pauseus tshort
addr3 = 0
for tmp = 0 to 7
addr3 = addr3 << 1
sck = 1
pauseus tmid
addr3 = addr3 + miso
sck = 0
pauseus tmid
next tmp
pauseus tshort
addr4 = 0
for tmp = 0 to 7
addr4 = addr4 << 1
sck = 1
pauseus tmid
addr4 = addr4 + miso
sck = 0
pauseus tmid
next tmp
pauseus tshort
addr5 = 0
for tmp = 0 to 7
addr5 = addr5 << 1
sck = 1
pauseus tmid
addr5 = addr5 + miso
sck = 0
pauseus tmid
next tmp
pauseus tshort
scn = 1
DataWrite:
scn = 0
pauseus tshort
for tmp = 0 to 7
mosi = addr.7
pauseus tshort
sck = 1
pauseus tmid
sck = 0
pauseus tmid
addr = addr << 1
next tmp
for tmp = 0 to 7
mosi = outdatl.7
pauseus tshort
sck = 1
pauseus tmid
sck = 0
pauseus tmid
next tmp
for tmp = 0 to 7
mosi = outdath.7
pauseus tshort
sck = 1
pauseus tmid
sck = 0
outdath = outdath << 1
pauseus tmid
next tmp
' 'FILL with zeroos
' for tmp = 0 to 15
' mosi = 0
' pauseus tshort
' sck = 1
' pauseus tmid
' sck = 0
' pauseus tmid
' next tmp
' SHIFTOUT mosi, sck, 1,[outdath]
pauseus tshort
scn = 1
DataRead:
scn = 0
for tmp = 0 to 7
mosi = addr.7
pauseus tshort
sck = 1
pauseus tmid
sck = 0
pauseus tmid
addr = addr << 1
next tmp
pauseus tshort
indatl = 0
for tmp = 0 to 7
sck = 1
pauseus tmid
sck = 0
pauseus tmid
next tmp
pauseus tshort
indath = 0
for tmp = 0 to 7
indath = indath << 1
sck = 1
pauseus tmid
indath = indath + miso
sck = 0
pauseus tmid
next tmp
scn = 1
Have fun.
