Problem with Timer Interrupt, PortB5-7 gets disabled
Dear fellows, I'm trying to implement a timer which would get enabled on a specific action perfor a specific task ones the time is reached.
I've achieved the timer thing using interrupts and breaking it down furthur and keeping a check on it. But achieving so i've came accross a number of problems
1. Serin/Serout data started to messup...so used disable/enable before and after to run serial communication smoothly...
2. Data read using names symbols on PortB failed so again disable/enable and used directly like PORTB instead of variable...this solved problem with Porb.0-Portb.4
3. Now the actual problem being: I'm unable to deal with my inputs at Portb.5-Portb.7...
I'm using 18F452 with a 4MHz XTAL
The code for my interrupt and all is:
'''''''''''''''''''''DEFINING and ENABLING INTERRUPT'''''''''''''''
T0CON = %11000111
INTCON = %00100000
On Interrupt GoTo SwitchOff
GoTo ProgramInitializationCont
Disable
SwitchOff:
If CountIntTimer < TimerInSMS Then
CountIntTimer = CountIntTimer + 1
INTCON.2 = 0
ElseIf CountIntTimer = TimerInSMS Then
Power = 1 'Power Off
Else
Resume
EndIf
Resume
Enable
''''''''''''''''''''''DEFINING and ENABLING INTERRUPT FINISHED'''''''''''''''
TimeInSMS = 100
ProgramInitializationCont:
If PortA.0 = 1 then
CountIntTimer = 0
INTCON.2 = 0
if PortB.7 = 1 then 'I'M NOT ABLE TO READ PORTB.5-7
'Some other action
''''''''''''''''''END OF CODE'''''''''''''''''''''''''''''''''
An urgent solution in timers implementation and PortB reuse would be appreciated
Best Regards
JD
PS: Although the code functions well on the OshonSoft PIC18 Simulator but am NOT ABLE TO READ MY PORTB IN PHYSICAL :(
