I want to calculate relative humidity to absolute humidity. result in g/kg
with the formula Av = (Rv * 1325,3 * 10^(7,5892 * T / (T+240,71)))/(T+273,15)
it should be possible to calculate the absolute humidity.
RV = relative humidity
T = temperature in degrees.
As you see, lots of huge numbers, comma's and even an exponentiation
Is a wizkid out there how knows to calculate this in PBP3? I'm using a PIC16F1936
Many thanks
Re: I want to calculate relative humidity to absolute humidity. result in g/kg
It's not to hard to do that...
Create lookup table in flash memory for this
for range you need, and step 1-10 degrees, depending on accuracy. Scale it to get most of byte, or word range. Then use interpolation to get more precise result.
Then just multiply Rv and value from lookup table. After that divide with absolute temp.
That way I have done this calculation http://www.picbasic.co.uk/forum/showthread.php?t=18483
