Funky I/O pin behavior on PIC12F629???
Problem 1. For some reason, pin 0 and pin 1 will not latch the output value when another pin output follows it. Other pins work fine (I know pin 3 is input only).
The code is as follows:
i var byte
loop: 'turn on LEDs
HIGH 0
pause 5000 ' led 0 will stay on for 5 seconds
HIGH 1 ' but will turn off here, and led 1 comes on
pause 5000 ' led 1 will then stay on for 5 seconds
HIGH 2 ' led 1 will turn off here, and led 2 comes on
pause 5000
HIGH 4 ' led 4 on, led 2 stays on, while 0 and 1 are off.
pause 5000
HIGH 5 ' led 5,4,2 stays on, while 0 and 1 are off
pause 10000
For i = 0 to 5 'turn off LEDs
LOW i
next
pause 10000
goto loop
Problem 2. Pin 1 for some reason can not be made an input.
PINS VAR PORTL
PIN0 VAR PINS.0
PIN1 VAR PINS.1
INPUT 1
IF PIN1 THEN
HIGH 0
What am I missing?
