Using the TMP100 series of I2C temperature sensor from Texas Instruments
Here is bits and pieces of code to help in interfacing a TMP100 series temperature sensor to your PIC project! They are nice and easy to use sensors, with 2 to 0.5°C accuracy and possibility of triggering alarms on low/high temp limit (TMP101). They are however quite small, in SOT23-6 package.
http://aberco.free.fr/imagesdivers/tmp100.jpg
Wire SDA and SDC to your pic (using 4.7k pullups) and ground A0 and A1 (or change the address in the code). For TMP101, A1 is replaced by ALERT which you can wire to an interrupt pin of the PIC.
When powered up, the TMP100 does automatic sampling. The following line can be sent to configure the sensor to 12bit resolution:
SCLpin VAR PORTB.6
SDApin VAR PORTB.4
TempH VAR Byte
TempL VAR Byte
I2CWRITE SDApin,SCLpin,$90,$01,[%01100100] 'Set continuous sampling at 12bit resolution
I2CREAD SDApin,SCLpin,$90,$00,[TempH,TempL] 'Read temperature sample
To save power between samples, the temperature sensor can be set to power off, and conversion can be triggered by sending a one shot sample request.
SCLpin VAR PORTB.6
SDApin VAR PORTB.4
TempH VAR Byte
TempL VAR Byte
I2CWRITE SDApin,SCLpin,$90,$01,[%01100101] 'Set 12 bit resolution, turn sensor off
SamplingLoop:
I2CWRITE SDApin,SCLpin,$90,$01,[%11100101] 'one-shot sample
PAUSE 350
GOTO SamplingLoop
Remember that a 12bit conversion does take 320ms to complete. Therefore after 1 shot sampling, you need to wait or you will read the previous value.
Temperature is read as a 16 bit value (TempH being MSB and TempL LSB). Here is the conversion routine to display the value on LCD (initialize your LCD first!):
TempSign VAR Byte
TempDec VAR Word
TempDec3 VAR Byte
TempDec2 VAR Byte
TempDec1 VAR Byte
TempDec0 VAR Byte
'Convert temperature to LCD
ConvertTemp:
IF TempH.7 = 1 THEN
TempSign = "-"
TempL = TempL ^ %11110000 'bitwise invert on the 4 MSB
TempL = TempL + 8 'adding 1 temperature unit
TempH = TempH ^ %11111111 'bitwise invert
IF TempL = 0 THEN
TempH = TempH + 1
TempSign = "+"
TempDec = 0
IF TempL.7 = 1 THEN TempDec = 5000
IF TempL.6 = 1 THEN TempDec = TempDec + 2500
IF TempL.5 = 1 THEN TempDec = TempDec + 1250
IF TempL.4 = 1 THEN TempDec = TempDec + 625
TempDec3 = TempDec DIG 3
TempDec2 = TempDec DIG 2
TempDec1 = TempDec DIG 1
TempDec0 = TempDec DIG 0
LCDOUT $FE,1, TempSign, #TempH, ".", #TempDec3,#TempDec2,#TempDec1,#TempDec0, "°C"
Hope it will help, enjoy!
