Driving two stepper motors
After some months, and considerable help from Bruce 'at Renton' - I've got my PBP code working to drive two stepper motors at the same time. This gives diagonal moves on an X/Y plotter.
The basic idea is that: X_steps * X_period = Y_steps * Y_period. So that both motors finish turning at the same time. I've used Timer0 and Timer1 with some asm code to make the pulses and PBP to work out the steps and periods.
To get a diagonal move one motor is set at one of the pre-define speeds(crawl,slow,fast..)
and the period of the other motor is calculated from the desired move.
To get the longest periods possible, the 'Prescales' of Timer0 and Timer1 are used if necessary. Timer0 is allocated to the Y axis because it's prescale goes to 'divide' by 256 and it's on the SHORTEST physical axis that you need the longest periods.
The code has tested well for a few days and, so far, is stable. It's far from gereral purpose code and is tuned to my home built XY plotter (scan area 16000 by 32000 steps so WORD variables can hold the data OK). I've also stripped out all the LCD, home/limit switch stuff and the input now is only by RS232 from a terminal at 9200 Baud.
I've posted it here because:
1. It may be a good starting point to writing your own XY plotter code - I can't find any code to make diagonal moves anywhere else?
2. Someone might spot better ways to doing this - advice and comments are welcome.
Finally - thank you very much Bruce; you got me started on interrupts and I'm now 'at ease' with them, simple asm and MPLAB.
The code is fairly well commented but I've worked with it so long that it's difficult to tell.
Regards Bill legge
' * File...... 8722 Scanner_RS232 *
' * Purpose... Plotter/Scanner XY table with diagonal moves *
' * Date...... April 2010 by Bill legge *
' 1. Outline: software for a XY plotter/scanner table, axis driven by stepper
' motors that can move at the same time to achieve diagonal plotting/scanning
' The main variables are:
' * Current location of the plot head: X_position, Y_position
' * Desired location: X_demand, Y_demand
' * Speed of move
' The X-demand, Y_demand and Speed words are input by RS232 @ 19200 Baud
' 2. MCU PIC18F8722. Board is Futurlec ET-BASE PIC8722 (ICD2) 10MHz Xtal
' 3. ETT relay board, opto isolated, active low, jumpers select PIC or Mach3 drive
' 4. ETT LED display, active low
' 5. ETT button input, active low
' 6. Chinese stepper dive, absolute max voltage is 24V, Use 20V. DB25 Pins:
' 1 X Drive To Port D0
' 2 Y Enable To Port D5. High = enable, low = disable
' 3 Y Direction To Port D4. Low = move up, high = move down
' 4 Z Direction Unused
' 5 Z Step Unused
' 6 Z Enable Unused
' 7 X Direction To Port D1. Low = move right, high = move left
' 8 Y Drive To Port D3
' 9 Relay Unused input
' 10 X Home To Port D6. Active low
' 11 Y Home To Port D7. Active low
' 12 Unused input
' 13 Unused input
' 14 X Enable To Port D2. High = enable, low = disable
' 15 Unused Input
' 16
' 17
' 18-25 Ground
' Mechanical
' Motor settings 200 steps/rev*16 pulses/step = 3,200 pulses/rev
' Belt pitch 2mm
' Pulley 36 teeth. 1rev = 36*2mm = 72mm
' X axis length 720mm = 10 revs = 32,000 pulses
' Y axis length 360mm = 5 revs = 16,000 pulses
' WORD [$ffff or 65,525] will hold maximum X or Y steps
' Motor Speeds
' MCU Osc is 4*10MHz. Period = 0.025uS. Tcy = 4*Period = 0.1uS
' Pulse periods: 800uS gives v.slow rotation and 100uS is maximum speed
' Use pulse rates that are 'powers of 2' so division/multiplication is fast
' Slug = 8192[Tcy] = 819.2uS = 819.2*3,200 = 2,621,440uS = 2.6S/rev (2^13)
' Slow = 4096[Tcy] = 409.6uS = 409.6*3,200 = 1,310,720uS = 1.3S/rev (2^12)
' Fast = 2048[Tcy] = 204.8uS = 204.8*3,200 = 655,360uS = 0.6S/rev (2^11)
' Race = 1024[Tcy] = 102.4uS = 102.4*3,200 = 327,680uS = 0.3S/rev (2^10)
' Timer1 in 16 Bit Mode, used for X axis
' Maximum count = $FFFF = 65,535
' Maximum prescale = 8
' Max count with max prescale = 65,535*8 = 524,280[Tcy]
' = 52,428uS = 52.4mS
' Timer0 in 16 Bit Mode, used for Y axis
' Maximum prescale = 256
' Max count with max prescale = 65,535*256 = 16,776,960[Tcy]
' = 1,677,696uS = 1677mS = 1.677 Seconds = 0.596Hz
' Straight Line Plots
' If the X or Y steps are zero, a special routine is used to avoid
' division by zero
' * INCLUDE & DEFINES *
clear
define OSC 40 ' Use HSPLL during compilation
DEFINE INTHAND Timer_ints
include "modedefs.bas" ' Include serout defines
define HSER_RCSTA 90h ' RS232-1 TX is C7, RX is C6
define HSER_TXSTA 24h
define HSER_BAUD 19200
define HSER_CLROERR 1
' * VARIABLES *
T0_delay var word BankA System ' Subtracted from 65,535 in asm
T1_delay var word BankA System ' Subtracted from 65,535 in asm
X_steps var word BankA System ' Steps to move = Demand - Current
Y_steps var word BankA System ' Steps to move = Demand - Current
lcount var byte BankA System ' Delay to make pulse out
X_position var word ' Current X position
Y_Position var word ' Current Y position
X_demand var word ' Demanded X position
Y_demand var word ' Demanded Y position
Temp_delay var long ' Holds temporaty pulse period calculations
Prescale var word ' Timer0/1 prescale to get long delays
Slug con 8192 ' Delay = 8192[Tcy]. 2^13. 1rev = 2.62S
Slow con 4096 ' Delay = 4096[Tcy]. 2^12. 1rev = 1.31S
Fast con 2048 ' Delay = 2048[Tcy]. 2^11. 1rev = 0.65S
Race con 1024 ' Delay = 1024[Tcy]. 2^10. 1rev = 0.33S
Speed var word ' Selected before issuing D_move command
X_drive var PORTD.0
X_dir var PORTD.1 ' Low = move right, high = move left
X_ena var PORTD.2 ' High = enable, low = disable
Y_drive var PORTD.3
Y_dir var PORTD.4 ' Low = move up, high = move down
Y_ena var PORTD.5 ' High = enable, low = disable
Heartbeat var PORTH.0 ' Green LED on MCU board
' * INITIALISE *
ADCON1 = %00001101 ' A0, A1 analog, rest digital
CMCON = %00000111 ' Comparators off, this frees up PORTF
TRISC = %10000000 ' C0-C3 is output, C6 is HSER Tx, C7 is HSER Rx
TRISD = %11000000 ' D0-D5 is stepper out, D6,D7 are HOME inputs
Speed = Slow ' 409.6uS pulses
goto Main ' Skip over ASM code
' * ASSEMBLER CODE *
Timer_ints
bcf INTCON,7 ; Disable all interrupts
btfss INTCON,TMR0IF ; Is Timer0 interrupt flag set?
bra Check_T1 ; No so branch to Timer1 interrupt
movff T0_delay+1,TMR0H ; Load Timer0 with delay_hb first
movff T0_delay,TMR0L ; Load Timer0 with delay_lb last
bcf INTCON,TMR0IF ; Clear Timer0 interrupt flag
bsf PORTD,3 ; T0 is always Y axis
call Short_pulse ; Make output pulse
bcf PORTD,3 ; Low Y drive
movf Y_steps,f ; Update STATUS register
btfsc STATUS,Z ; Is low byte zero?
decf Y_steps+1,f ; Yes so decrement high byte
decf Y_steps,f ; Decrament low byte
Check_T1
btfss PIR1,TMR1IF ; Is Timer1 interrupt flag set?
bra Int_exit ; No so branch to end of ISR
movff T1_delay+1,TMR1H ; Load Timer0 with delay_hb first
movff T1_delay,TMR1L ; Load Timer0 with delay_lb last
bcf PIR1,TMR1IF ; Clear Timer1 interrupt flag
bsf PORTD,0 ; T1 is always X axis
bcf PORTD,0 ; low X drive
movf X_steps,f ; Update STATUS register
decf X_steps+1,f ; Yes so decrement high byte
decf X_steps,f ; Decrament low byte
Int_exit
bsf INTCON,7 ; Enable all interrupts
retfie FAST ; Return automatic restore
; Pulse out subroutine
Short_pulse ; Delay = 3.n+7 [0.1uS]
movlw 0x62 ; $21 = 10uS, $62 = 30uS, $ff = 77.2uS
movwf lcount
Pulse_loop
decfsz lcount ; Decrement the file Count
goto Pulse_loop ; Loop if not zero
;* MAIN ASM *
_Main_ASM
comf T0_delay+1 ; So that the computed delay
comf T0_delay ; does not have to be subtracted
comf T1_delay+1 ; from 65,535, the overflow
comf T1_delay ; of Timer0 and Timer1 in 16 bit mode
; Set up interrupt conditions
bcf RCON,7 ; Disable priority levels, IPEN=0
bsf INTCON,7 ; Enable all unmasked interrupts
bsf INTCON,6 ; Enable all unmasked peripheral interrupts
bcf INTCON,3 ; Disable PORTB interrupts
bcf INTCON2,2 ; Timer0 overflow low priority
bcf IPR1,0 ; Timer1 overflow low priority
; Load timers, T0CON and T1CON set in PBP
movff T0_delay,TMR0L ; Load Timer0 with delay_lb after hi byte
movff T1_delay+1,TMR1H ; Load Timer1 with delay_hb first
movff T1_delay,TMR1L ; Load Timer1 with delay_lb after hi byte
bcf INTCON,TMR0IF ; Timer0 clear interrupt flag
bsf INTCON,TMR0IE ; Timer0 enable interrupt
bcf PIR1,TMR1IF ; Timer1 clear interrupt flag
bsf PIE1,TMR1IE ; Timer1 enable interrupt
Main_loop
tstfsz X_steps+1 ; Is high byte zero?
goto Test_Y ; Not zero so test Y_steps
tstfsz X_steps ; Is low byte zero?
bcf PIE1,TMR1IE ; Is zero so disable Timer1 interrupt
bcf PIR1,TMR1IF ; Is zero so clear Timer1 flag
movlw b'10000000' ; Stop timer1 running
movwf T1CON ; Kill Timer1 now
Test_Y
tstfsz Y_steps+1 ; Is high byte zero?
goto Main_loop ; Not zero so keep running
tstfsz Y_steps ; Is low byte zero?
goto Main_loop ; Not zero so do it all again
bcf INTCON,TMR0IE ; Timer0 disable interrupt
movlw b'00000000' ; Stop Timer0 running
movwf T0CON ; Kill timer0 now
btfsc PIE1,TMR1IE ; Has Timer1 interrupt been killed?
All_done
' * MAIN *
Speed = Slow
gosub RS232_input
gosub D_move
toggle Heartbeat
goto Main
' * DIAGONAL MOVE. Move to X_demand, Y_demand and update X/Y_position *
D_move:
if X_demand > 32000 then X_demand = 32000 ' X upper limit
IF Y_demand > 16000 THEN Y_demand = 16000 ' Y upper limit
if X_demand>=X_position then
low X_dir ' Move right
X_Steps = X_demand - X_position
Else
High X_dir ' Move left
X_Steps = X_position - X_demand
if Y_demand>=Y_position then
low Y_dir ' Move up
Y_Steps = Y_demand - Y_position
HIGH Y_dir ' Move down
Y_Steps = Y_position - Y_demand
if X_steps = 0 then ' Only Y_steps, only Timer0 needed
T0_delay = Speed ' Timer0 delay is fixed
T0CON = %10001000 ' Timer0 on, 16 bit, prescale=1
T1CON = %10000000 ' Timer1 off
goto D_move_done ' No X steps to do so end
IF Y_steps = 0 then ' Only X_steps, only Timer1 needed
T1_delay = Speed ' Timer1 delay is fixed
T1CON = %10000001 ' Timer1 on, 16 bit, prescale=1
T0CON = %00001000 ' Timer0 off
goto D_move_done ' No Y steps to do so end
if X_steps >= Y_steps then
Temp_delay = X_steps*Speed ' Calculate Timer0 delay
Temp_delay = Temp_delay/Y_steps ' Delay needed without prescale in [Tcy]
gosub Get_T0_prescale ' Now divide delay by prescale
goto D_move_done
Temp_delay = Y_steps*Speed ' Calculate Timer1 delay
Temp_delay = Temp_delay/X_steps ' Delay needed without prescale in [Tcy]
gosub Get_T1_prescale ' Now divide delay by prescale
goto D_move_done
D_move_done:
CALL Main_ASM ' Make the pulses
X_position=X_demand ' Move done so position = demand
Y_position=Y_demand ' Move done so position = demand
' * SUB-ROUTINES *
Get_T0_Prescale:
select case Temp_delay
case is > 8388480
T0CON = %10000111
Prescale = 8 ; Divide by 2.2.2.2.2.2.2.2
case is > 4194240
T0CON = %10000110
Prescale = 7 ; Divide by 2.2.2.2.2.2.2
case is > 2097120
T0CON = %10000101
Prescale = 6 ; Divide by 2.2.2.2.2.2
case is > 1048560
T0CON = %10000100
Prescale = 5 ; Divide by 2.2.2.2.2
case is > 524280
T0CON = %10000011
Prescale = 4 ; Divide by 2.2.2.2
case is > 262140
T0CON = %10000010
Prescale = 3 ; Divide by 2.2.2
case is > 131070
T0CON = %10000001
Prescale = 2 ; Divide by 2.2
case is > 65535
T0CON = %10000000
Prescale = 1 ; Divide by 2
case else
T0CON = %10001000
Prescale = 0 ; Divide by 1
end select
Temp_delay = Temp_delay >> Prescale
T0_delay = Temp_delay.word0
Get_T1_Prescale:
case is > 262140
T1CON = %10110001
case is > 131070
T1CON = %10100001
case is > 65535
T1CON = %10010001
case else
T1CON = %10000001
end select
T1_delay = Temp_delay.word0
' * RS232 INPUT. Get X_demand, Y_demand from terminal *
RS232_input:
hserout ["X-demand 0 to 32000",13]
hserout ["Y_demand 0 to 16000",13]
hserout ["Speed 2000(fast) to 8000(slow)",13]
hserout ["Enter X_demand, Y_demand, Speed",13]
hserin [dec X_demand,dec Y_demand,dec Speed]
hserout ["You entered ",dec X_demand," ",dec Y_demand," ",dec Speed,13]
Drivin two stepper motors
Tenaja,
Thanks for your comment. That's a good idea - I presume toggling the drive pins will be OK as long as they stay high for the minimum time for my driver - 5uS.
I'll give it a try.
What I want to do next is incorporate a ramp-up/down (for constant accelleration) but can't see how to do it with both motors?
I've done it with one motor OK:
1. Using a list of pulse times held in EEPROM, as in David Benson,s book 'Easy Step'n'.
2. Using a maths routine to calculate the periods - too slow in PBP.
Any ideas how to do it with two motors?
Regards Bill Legge
Tanaja,
Yes, I've seen the embedded.com article by David Austin. There is also a good application note on the ATMEL site (Application note AVR446) that has rampup/down calculation:
Cn = Cn_1 - 2*Cn_1/(4n+1)
In the C language - I have yet to see if PBP is fast enough to do this.
Was the formula you used like the one above or was it the more complicated 'exact' calculation that needs square roots? If it takes 105uS that's in the ball park for my application.
Re 'context saving' - if you mean 'wsave' and so on - I don't think it's necessary on the PIC18F8722?
Regards Bill Legge
