I2C Ping program
This program tests every valid 8bit write address connected to the I2C bus.
- Confirms you have your connections correct
- Confirms your pull-ups are correct
- Tells you what your I2C address is.
I hope this is useful to people
TimC
' I2C Scanner to find devices on I2C Bus
' If a I2C device is functional it will return it's address
' Tim 3/29/04
DEFINE LOADER_USER 1 ' Boot-Loader is being used
DEFINE OSC 20 ' Change to your chip
DEFINE HSER_BAUD 9600 ' override the default of 2400
SDA VAR portc.4 ' change if needed
SCL VAR portc.3 ' change if needed
LED VAR portd.1 ' change if needed
i2c_out VAR BYTE ' dummy data to sent over I2C bus
i2c_ack VAR BIT 'acknowledgement bit
CMCON = 7 ' disable the analog comparator your chip may be different
pause 500 ' just because we don't know what we are pinging
HSEROUT [" *** Start I2C Ping ***",13,10] ' announce
looper:
for i2c_out = 2 to $fe step 2 ' Remove step to find both reading and writing address.
gosub I2c_Ping
if i2c_ack = 0 then
HSEROUT ["$",hex2 i2c_out, " "] '
gosub heartbeat ' just in case there is no serial port
next i2c_out
HSEROUT [13,10," *** Fini I2C Ping ***",13,10] ' say we are done
' Subs
I2C_Ping: 'Start Conversion
GOSUB I2C_START
'i2c_out = %10010000 'Send Address, (device= %1001, A0= 0, A1= 0, A2= 0, R/W= 0)
GOSUB I2C_TX
GOSUB I2C_STOP
I2C_TX: 'I2C transmit -> send data to the slave
i2c_ack = 1 'ACK bit will change to 0 if device is found
SHIFTOUT SDA,SCL,1,[i2c_out] 'Shift out “i2c_out” MSBfirst
SHIFTIN SDA,SCL,0,[i2c_ack\1] 'Receive ACK bit
I2C_START: 'I2C start (start communication on I2C bus)
HIGH SDA
HIGH SCL
LOW SDA
LOW SCL
I2C_STOP: 'I2C stop (terminate communication on I2C bus)
LOW SDA
HIGH SCL
HIGH SDA
PAUSE 1
' Subroutine to blink a pin for heartbeat
heartbeat:
high LED ' turn on led no tris needed
pause 100 ' for .1 seconds
low LED ' turn off led
pause 500 ' for .5 seconds
Output should look like this:
$78
If you have more than one device you will see more addresses.
TimC
