Change variable allocation to save code space
Dear everyone,
I have a quick question regarding what could be a trivial problem, I am driving a complex LED matrix which is fed through a series of shift registers. The output are out of order, so I have to reconstruct the correct sequence using a brightness array. I then used some modifiers to get the right order:
LEDPattern VAR BYTE[80]
RedSegment1 VAR LEDPattern[23]
RedSegment2 VAR LEDPattern[21]
RedSegment3 VAR LEDPattern[15]
RedSegment4 VAR LEDPattern[12]
RedSegment5 VAR LEDPattern[6]
RedSegment6 VAR LEDPattern[4]
RedSegment7 VAR LEDPattern[26]
Now I have a series of subroutines designed to display a series of patterns. Some are quite complex, but some are simple like this one to turn all the red segments on:
RedSegment1 = 8
RedSegment2 = 8
RedSegment3 = 8
RedSegment4 = 8
RedSegment5 = 8
RedSegment6 = 8
Is there a better solution for doing this to save some code space? I could use a FOR loop but I cannot refer to the variable change as with an array...
Thanks for the help!
Re: Change variable allocation to save code space
I don't know if it will work in your case, but you can use an array to point to an index in another array.
Something like
Arraywrite OffsetArray,[0,23,21,15,12,6,4,26]
For X = 1 to 8
Temp = OffsetArray[X]
LEDPattern[Temp] = 8
Next X
Good point, I thought about doing this, but it just transfer the program memory overhead into the RAM right as it will mean creating another whole 80 byte array, right? Also I will have to fill OffsetArray with a series of 80 constants which will go right into program memory.
I'm using a 16F648A with 256B of RAM and the compiler cannot fit two such large arrays into contiguous banks right now. Granted that I probably have some optimizations left on the program, I will not be able to free up much RAM space though...
Is it fair to ask why you don't simply use a big 18F part to begin with? Optimizing code to fit a small device might be rewarding, but it generally isn't cost-effective from a time standpoint uless you are making several hundred or more.
Yes, I have looked in microchip catalog, but there is no SOIC 18 pin compatible parts with more code memory... The 16F88 does have 384B of RAM and is the only 18 pin with better features. Of course I have already made 60x13 cm double sized PCBs which were quite expensive, so I have to use the SOIC18 layout. It seems that the 18F family has discarded the 18pin footprint.
I am reaching the 4k word limit which only restrain me from adding more animations. It is not a serious problem but I thought I could do a better job than having more than 200 lines of "Variable = Value" in my program.
With some creative thinking and some luck you might add an EEprom. It could be possible to solder it directly onto the PIC itself. Piggy-back the EEprom and set the i2c bus to drivven and you might even get away without adding the pullup resistors for sda and scl.
It is only 4 pins (GND, VDD, SDA, SCL) you need to connect between the PIC and the eeprom, the other pins on the EEPROM you connect either to GND or VDD (address, RW). Microchip have alot of I2C eeproms in different sizes and packages so if you just have 2 un-used pins on the pic in a suitable position this might be an option.
Then you can add alot of LED patterns and use the I2C command to load them into the RAM variables when you need to display the pattern.
Hi Aberco,
I use alot of 16F87s which has the same pinout as the 16F88. I needed more code space to do more things with my product without adding parts to the board. Microchip recently came out with the 16F1847 which has 8K of code space and 1024 bytes of ram and 256 bytes of EEPROM and is available in your SOIC format. You can only program it with PBP3 and if you are using an MELabs USB programming you will need to update the software on it. You will also need the latest MCS software that comes with PBP3.
HTH,
BobK
EEPROM will not be possible as there is no footprint on the PCB.
I have suppressed all the redundancy in the remaining of the code and managed to free more than 800 words (more than 20%!). I still have those long sequences of variable allocation though... but maybe it is not possible to do any better than that afteral.
Never say never. It's amazing how we could shrink it.... assuming we could see the code. BobK's advice seems fair too.
Oh yeah, coming from hardware development as a hobby I am very excited to start mastering a bit more microcontrollers. Makes a whole new world of possibilities!
Now my code is working absolutely flawlessly. I have not much reason to change it but I'd like to learn about possibilities to further shrink the code as it seems to be very redundant right now... with my latest optimizations it compiles with around 3150 words so there is still some free space.
Project is a LED sign that I have designed for a friend. There are now 52 different animations that are all listed in the table below. The names at the top of the matrix are the subroutine that needs to be called to execute the corresponding animation
http://i56.tinypic.com/s1l2fd.jpg
And the full program:
'* Name : Tattoosign.pbp *
'* Author : Antoine Bercovici *
'* Date : 08/08/2011 *
'* Version : 1.0 *
__config _HS_OSC & _WDT_ON & _MCLRE_ON & _BOREN_OFF & _LVP_OFF & _CP_ON
DEFINE OSC 20
DEFINE LOADER_USED 1
clear
'Init for PIC16F648A
CMCON = %00000111 'Disable comparator module
TRISA = %00000000 'All PortA is output
TRISB = %00000001 'All PortB is output, PortB.0 is input
INTCON = %00010000 'Enable Interrupt on PortB.0
OPTION_REG.6 = 0 'Interrupt on falling edge 1->0 transition
'I/O port declaration
DATShift VAR PORTA.2
CLKShift VAR PortB.1
STRShift VAR PortB.3
PushButton VAR PortB.0
'Variable declaration
ShiftCounter VAR BYTE
PWMCounter VAR Byte
AnimationCounter VAR BYTE
AnimationSpeed VAR WORD
AnimationStyle VAR BYTE
AnimationNumber VAR BYTE
StoredAnimationSpeed VAR BYTE
SpeedCounter VAR WORD
ButtonCounter VAR BYTE
PhaseCounter VAR BYTE
Buffer VAR BYTE
DemoMode VAR BIT
DemoCounter VAR WORD
LEDPattern VAR BYTE[76]
Phase VAR BYTE[16]
RedSegment8 VAR LEDPattern[17]
RedSegment9 VAR LEDPattern[19]
RedSegment10 VAR LEDPattern[10]
RedSegment11 VAR LEDPattern[8]
RedSegment12 VAR LEDPattern[2]
RedSegment13 VAR LEDPattern[0]
RedSegment14 VAR LEDPattern[30]
RedSegment15 VAR LEDPattern[28]
RedSegment16 VAR LEDPattern[35]
RedSegment17 VAR LEDPattern[38]
RedSegment18 VAR LEDPattern[36]
RedSegment19 VAR LEDPattern[33]
RedSegment20 VAR LEDPattern[55]
RedSegment21 VAR LEDPattern[53]
RedSegment22 VAR LEDPattern[43]
RedSegment23 VAR LEDPattern[46]
RedSegment24 VAR LEDPattern[44]
RedSegment25 VAR LEDPattern[41]
RedSegment26 VAR LEDPattern[48]
RedSegment27 VAR LEDPattern[56]
RedSegment28 VAR LEDPattern[58]
RedSegment29 VAR LEDPattern[62]
RedSegment30 VAR LEDPattern[60]
RedSegment31 VAR LEDPattern[74]
RedSegment32 VAR LEDPattern[64]
RedSegment33 VAR LEDPattern[66]
RedSegment34 VAR LEDPattern[70]
RedSegment35 VAR LEDPattern[68]
GreenSegment1 VAR LEDPattern[24]
GreenSegment2 VAR LEDPattern[22]
GreenSegment3 VAR LEDPattern[20]
GreenSegment4 VAR LEDPattern[13]
GreenSegment5 VAR LEDPattern[7]
GreenSegment6 VAR LEDPattern[5]
GreenSegment7 VAR LEDPattern[27]
GreenSegment8 VAR LEDPattern[25]
GreenSegment9 VAR LEDPattern[18]
GreenSegment10 VAR LEDPattern[11]
GreenSegment11 VAR LEDPattern[9]
GreenSegment12 VAR LEDPattern[3]
GreenSegment13 VAR LEDPattern[1]
GreenSegment14 VAR LEDPattern[31]
GreenSegment15 VAR LEDPattern[29]
GreenSegment16 VAR LEDPattern[51]
GreenSegment17 VAR LEDPattern[39]
GreenSegment18 VAR LEDPattern[37]
GreenSegment19 VAR LEDPattern[32]
GreenSegment20 VAR LEDPattern[50]
GreenSegment21 VAR LEDPattern[54]
GreenSegment22 VAR LEDPattern[52]
GreenSegment23 VAR LEDPattern[47]
GreenSegment24 VAR LEDPattern[45]
GreenSegment25 VAR LEDPattern[40]
GreenSegment26 VAR LEDPattern[49]
GreenSegment27 VAR LEDPattern[72]
GreenSegment28 VAR LEDPattern[59]
GreenSegment29 VAR LEDPattern[63]
GreenSegment30 VAR LEDPattern[61]
GreenSegment31 VAR LEDPattern[75]
GreenSegment32 VAR LEDPattern[73]
GreenSegment33 VAR LEDPattern[67]
GreenSegment34 VAR LEDPattern[71]
GreenSegment35 VAR LEDPattern[69]
TattooSegment1 VAR LEDPattern[14]
TattooSegment2 VAR LEDPattern[16]
TattooSegment3 VAR LEDPattern[34]
TattooSegment4 VAR LEDPattern[42]
TattooSegment5 VAR LEDPattern[57]
TattooSegment6 VAR LEDPattern[65]
Phase1 VAR Phase[1]
Phase2 VAR Phase[2]
Phase3 VAR Phase[3]
Phase4 VAR Phase[4]
Phase5 VAR Phase[5]
Phase6 VAR Phase[6]
Phase7 VAR Phase[7]
Phase8 VAR Phase[8]
Phase9 VAR Phase[9]
Phase10 VAR Phase[10]
Phase11 VAR Phase[11]
Phase12 VAR Phase[12]
Phase13 VAR Phase[13]
Phase14 VAR Phase[14]
Phase15 VAR Phase[15]
Phase16 VAR Phase[16]
'Init the interrupt handling system
INCLUDE "DT_INTS-14.bas" 'Base Interrupt System
INCLUDE "ReEnterPBP.bas" 'Include if using PBP interrupts
INT_Handler INT_INT, _ButtonInterrupt, PBP, Yes
wsave VAR BYTE $70 SYSTEM 'alternate save location for W, for DT_INTS use
'Program start
ShiftCounter = 0
AnimationCounter = 0
SpeedCounter = 255
ButtonCounter = 0
DemoMode = 0
DemoCounter = 0
AnimationNumber = 51
READ 0, AnimationStyle
READ 1, StoredAnimationSpeed
IF PushButton = 0 THEN
DemoMode = 1
AnimationStyle = 0
StoredAnimationSpeed = 5
@ INT_ENABLE INT_INT ; enable Button interrupt
'Main program loop
MainLoop:
Gosub AnimationUpdate
GOSUB DisplayLoop
GOTO MainLoop
'Do one display loop
DisplayLoop:
FOR PWMCounter = 0 TO 8 'There are 9 PWM shades from 0 (all off) to 8 (all on)
FOR ShiftCounter = 79 TO 0 STEP - 1
IF LedPattern[ShiftCounter] > PWMCounter THEN
LOW DATShift
HIGH DATShift
HIGH CLKShift
LOW CLKShift
Next ShiftCounter
HIGH STRShift
LOW STRShift
NEXT PWMCounter
'Update one step for animation status
AnimationUpdate:
IF DemoMode = 1 THEN
DemoCounter = DemoCounter + 1
IF DemoCounter >= 1200 THEN
DemoCounter = 0
AnimationStyle = AnimationStyle + 1
IF AnimationStyle > AnimationNumber THEN AnimationStyle = 0
LOOKUP StoredAnimationSpeed, [6, 8, 10, 12, 14, 17, 21, 27, 33, 50, 80, 160, 0], AnimationSpeed
IF AnimationStyle > 31 THEN AnimationSpeed = AnimationSpeed * 2
IF SpeedCounter >= AnimationSpeed THEN
SpeedCounter = 0
IF AnimationSpeed > 0 THEN AnimationCounter = AnimationCounter + 1
IF AnimationCounter >= 16 THEN AnimationCounter = 0 'There are 16 steps for an animation loop
SpeedCounter = SpeedCounter + 1
IF AnimationStyle <= 27 THEN GOSUB MonoGradient
IF AnimationStyle >= 28 AND AnimationStyle <= 31 THEN GOSUB PolyGradient
IF AnimationStyle >= 32 AND AnimationStyle <= 37 THEN GOSUB NarrowColorBanding
IF AnimationStyle >= 38 THEN GOSUB MediumColorBanding
GOSUB TurnAllOff
Select CASE AnimationStyle
CASE 1
GOSUB TurnRedON
Case 2
GOSUB TurnGreenON
CASE 3
GOSUB TurnRedON
GOSUB TurnGreenON
CASE 4, 5
GOSUB RedGradient
CASE 6, 7
GOSUB GreenGradient
CASE 8, 9
GOSUB RedGradient
GOSUB GreenGradient
CAsE 10, 11
GOSUB TurnGreenON
GOSUB RedGradient
CASE 12, 13
GOSUB TurnRedON
GOSUB GreenGradient
CASE 14, 15
GOSUB VerticalRedGradient
CASE 16, 17
GOSUB VerticalGreenGradient
CASE 18, 19
CASE 20, 21
GOSUB TurnGreenON
CASE 22, 23
GOSUB TurnRedON
CASE 24
GOSUB MonoRedGradient
CASE 25
GOSUB MonoGreenGradient
CASE 26
CASE 27
GOSUB MonoRedAntiGradient
Case 28, 29
GOSUB GreenGradient
GOSUB RedAntiGradient
CASE 30, 31
GOSUB VerticalRedAntiGradient
CASE 32
GOSUB RedGradient
CASE 33
GOSUB GreenGradient
CASE 34
GOSUB RedGradient
GOSUB GreenGradient
CASE 35
GOSUB TurnGreenON
GOSUB RedGradient
CASE 36
GOSUB TurnRedON
GOSUB GreenGradient
CASE 37, 38, 39
GOSUB GreenGradient
GOSUB RedShortAntiGradient
CASE 40, 41
GOSUB RedGradient
CASE 42, 43
GOSUB GreenGradient
CASE 44, 45
GOSUB RedGradient
GOSUB GreenGradient
CASE 46, 47
GOSUB TurnGreenON
GOSUB RedGradient
CASE 48, 49
GOSUB TurnRedON
GOSUB GreenGradient
CASE 50, 51
GOSUB GreenGradient
GOSUB RedMediumAntiGradient
END SELECT
GOSUB TurnTATTOOon
'Monochromatic gradient Right
MonoGradient:
FOR PhaseCounter = 0 TO 15
LOOKUP AnimationCounter + PhaseCounter, [0, 1, 2, 3, 4, 5, 6, 7, 8, 7, 6, 5, 4, 3, 2, 1, 0, 1, 2, 3, 4, 5, 6, 7, 8, 7, 6, 5, 4, 3, 2, 1], Buffer
GOSUB GradientDirection
NEXT PhaseCounter
'Polychromatic gradient
PolyGradient:
LOOKUP AnimationCounter + PhaseCounter, [0, 2, 4, 6, 8, 8, 8, 8, 8, 8, 8, 8, 8, 6, 4, 2, 0, 2, 4, 6, 8, 8, 8, 8, 8, 8, 8, 8, 8, 6, 4, 2], Buffer
NEXT PhaseCounter
'Narrow color banding
NarrowColorBanding:
Buffer = AnimationCounter + PhaseCounter
IF Buffer.0 = 0 THEN
Buffer = 0
Buffer = 8
Phase[PhaseCounter + 1] = Buffer
NEXT PhaseCounter
'Medium color banding
MediumColorBanding:
IF Buffer.1 = 0 THEN
Buffer = 0
Buffer = 8
NEXT PhaseCounter
'Gradient Direction is left or right
GradientDirection:
IF AnimationStyle.0 = 0 THEN
Phase[16 - PhaseCounter] = Buffer
'Turn all LEDs off
TurnAllOff:
FOR ShiftCounter = 0 TO 75
LedPattern[ShiftCounter] = 0
Next ShiftCounter
'Turn TATTOO on
TurnTATTOOon:
TattooSegment1 = 8
TattooSegment2 = 8
TattooSegment3 = 8
TattooSegment4 = 8
TattooSegment5 = 8
TattooSegment6 = 8
'TATTOO Gradient
'TATTOOGradient:
'TattooSegment1 = Phase1
'TattooSegment2 = Phase1
'TattooSegment3 = Phase1
'TattooSegment4 = Phase1
'TattooSegment5 = Phase1
'TattooSegment6 = Phase1
'TATTOO shift
'TATTOOShift:
'TattooSegment2 = Phase2
'TattooSegment3 = Phase3
'TattooSegment4 = Phase4
'TattooSegment5 = Phase5
'TattooSegment6 = Phase6
'RETURN
'Turn Green segments on
TurnGreenOn:
GreenSegment1 = 8
GreenSegment2 = 8
GreenSegment3 = 8
GreenSegment4 = 8
GreenSegment5 = 8
GreenSegment6 = 8
GreenSegment7 = 8
GreenSegment8 = 8
GreenSegment9 = 8
GreenSegment10 = 8
GreenSegment11 = 8
GreenSegment12 = 8
GreenSegment13 = 8
GreenSegment14 = 8
GreenSegment15 = 8
GreenSegment16 = 8
GreenSegment17 = 8
GreenSegment18 = 8
GreenSegment19 = 8
GreenSegment20 = 8
GreenSegment21 = 8
GreenSegment22 = 8
GreenSegment23 = 8
GreenSegment24 = 8
GreenSegment25 = 8
GreenSegment26 = 8
GreenSegment27 = 8
GreenSegment28 = 8
GreenSegment29 = 8
GreenSegment30 = 8
GreenSegment31 = 8
GreenSegment32 = 8
GreenSegment33 = 8
GreenSegment34 = 8
GreenSegment35 = 8
'Turn Red segments on
TurnRedOn:
RedSegment1 = 8
RedSegment2 = 8
RedSegment3 = 8
RedSegment4 = 8
RedSegment5 = 8
RedSegment6 = 8
RedSegment7 = 8
RedSegment8 = 8
RedSegment9 = 8
RedSegment10 = 8
RedSegment11 = 8
RedSegment12 = 8
RedSegment13 = 8
RedSegment14 = 8
RedSegment15 = 8
RedSegment16 = 8
RedSegment17 = 8
RedSegment18 = 8
RedSegment19 = 8
RedSegment20 = 8
RedSegment21 = 8
RedSegment22 = 8
RedSegment23 = 8
RedSegment24 = 8
RedSegment25 = 8
RedSegment26 = 8
RedSegment27 = 8
RedSegment28 = 8
RedSegment29 = 8
RedSegment30 = 8
RedSegment31 = 8
RedSegment32 = 8
RedSegment33 = 8
RedSegment34 = 8
RedSegment35 = 8
'Green gradient 45°
GreenGradient:
GreenSegment1 = Phase1
GreenSegment2 = Phase2
GreenSegment3 = Phase3
GreenSegment4 = Phase4
GreenSegment5 = Phase5
GreenSegment6 = Phase6
GreenSegment7 = Phase3
GreenSegment8 = Phase4
GreenSegment9 = Phase5
GreenSegment10 = Phase6
GreenSegment11 = Phase7
GreenSegment12 = Phase8
GreenSegment13 = Phase9
GreenSegment14 = Phase9
GreenSegment15 = Phase10
GreenSegment16 = Phase11
GreenSegment17 = Phase12
GreenSegment18 = Phase13
GreenSegment19 = Phase14
GreenSegment20 = Phase13
GreenSegment21 = Phase14
GreenSegment22 = Phase15
GreenSegment23 = Phase16
GreenSegment24 = Phase1
GreenSegment25 = Phase2
GreenSegment26 = Phase16
GreenSegment27 = Phase1
GreenSegment28 = Phase2
GreenSegment29 = Phase3
GreenSegment30 = Phase4
GreenSegment31 = Phase4
GreenSegment32 = Phase5
GreenSegment33 = Phase6
GreenSegment34 = Phase7
GreenSegment35 = Phase8
'Red gradient 45°
RedGradient:
RedSegment1 = Phase1
RedSegment2 = Phase2
RedSegment3 = Phase3
RedSegment4 = Phase4
RedSegment5 = Phase5
RedSegment6 = Phase6
RedSegment7 = Phase3
RedSegment8 = Phase4
RedSegment9 = Phase5
RedSegment10 = Phase6
RedSegment11 = Phase7
RedSegment12 = Phase8
RedSegment13 = Phase9
RedSegment14 = Phase9
RedSegment15 = Phase10
RedSegment16 = Phase11
RedSegment17 = Phase12
RedSegment18 = Phase13
RedSegment19 = Phase14
RedSegment20 = Phase13
RedSegment21 = Phase14
RedSegment22 = Phase15
RedSegment23 = Phase16
RedSegment24 = Phase1
RedSegment25 = Phase2
RedSegment26 = Phase16
RedSegment27 = Phase1
RedSegment28 = Phase2
RedSegment29 = Phase3
RedSegment30 = Phase4
RedSegment31 = Phase4
RedSegment32 = Phase5
RedSegment33 = Phase6
RedSegment34 = Phase7
RedSegment35 = Phase8
'Red gradient 45° Antiphase
RedAntiGradient:
RedSegment1 = Phase9
RedSegment2 = Phase10
RedSegment3 = Phase11
RedSegment4 = Phase12
RedSegment5 = Phase13
RedSegment6 = Phase14
RedSegment7 = Phase11
RedSegment8 = Phase12
RedSegment9 = Phase13
RedSegment10 = Phase14
RedSegment11 = Phase15
RedSegment12 = Phase16
RedSegment13 = Phase1
RedSegment14 = Phase1
RedSegment15 = Phase2
RedSegment16 = Phase3
RedSegment17 = Phase4
RedSegment18 = Phase5
RedSegment19 = Phase6
RedSegment20 = Phase5
RedSegment21 = Phase6
RedSegment22 = Phase7
RedSegment23 = Phase8
RedSegment24 = Phase9
RedSegment25 = Phase10
RedSegment26 = Phase8
RedSegment27 = Phase9
RedSegment28 = Phase10
RedSegment29 = Phase11
RedSegment30 = Phase12
RedSegment31 = Phase12
RedSegment32 = Phase13
RedSegment33 = Phase14
RedSegment34 = Phase15
RedSegment35 = Phase16
'Red gradient 45° with 1 step Antiphase
RedShortAntiGradient:
RedSegment1 = Phase2
RedSegment2 = Phase3
RedSegment3 = Phase4
RedSegment4 = Phase5
RedSegment5 = Phase6
RedSegment6 = Phase7
RedSegment7 = Phase4
RedSegment8 = Phase5
RedSegment9 = Phase6
RedSegment10 = Phase7
RedSegment11 = Phase8
RedSegment12 = Phase9
RedSegment13 = Phase10
RedSegment14 = Phase10
RedSegment15 = Phase11
RedSegment16 = Phase12
RedSegment17 = Phase13
RedSegment18 = Phase14
RedSegment19 = Phase15
RedSegment20 = Phase14
RedSegment21 = Phase15
RedSegment22 = Phase16
RedSegment24 = Phase2
RedSegment25 = Phase3
RedSegment27 = Phase2
RedSegment28 = Phase3
RedSegment29 = Phase4
RedSegment30 = Phase5
RedSegment31 = Phase5
RedSegment32 = Phase6
RedSegment33 = Phase7
RedSegment34 = Phase8
RedSegment35 = Phase9
'Red gradient 45° with 2 step Antiphase
RedMediumAntiGradient:
RedSegment1 = Phase3
RedSegment2 = Phase4
RedSegment3 = Phase5
RedSegment4 = Phase6
RedSegment5 = Phase7
RedSegment6 = Phase8
RedSegment7 = Phase5
RedSegment8 = Phase6
RedSegment9 = Phase7
RedSegment10 = Phase8
RedSegment11 = Phase9
RedSegment12 = Phase10
RedSegment13 = Phase11
RedSegment14 = Phase11
RedSegment15 = Phase12
RedSegment16 = Phase13
RedSegment17 = Phase14
RedSegment18 = Phase15
RedSegment19 = Phase16
RedSegment20 = Phase15
RedSegment21 = Phase16
RedSegment23 = Phase2
RedSegment24 = Phase3
RedSegment25 = Phase4
RedSegment26 = Phase2
RedSegment27 = Phase3
RedSegment28 = Phase4
RedSegment29 = Phase5
RedSegment30 = Phase6
RedSegment31 = Phase6
RedSegment32 = Phase7
RedSegment33 = Phase8
RedSegment34 = Phase9
RedSegment35 = Phase10
'Vertical Green gradient
VerticalGreenGradient:
GreenSegment2 = Phase1
GreenSegment3 = Phase1
GreenSegment4 = Phase1
GreenSegment5 = Phase1
GreenSegment6 = Phase1
GreenSegment7 = Phase2
GreenSegment8 = Phase2
GreenSegment9 = Phase2
GreenSegment10 = Phase2
GreenSegment11 = Phase2
GreenSegment12 = Phase2
GreenSegment13 = Phase2
GreenSegment14 = Phase3
GreenSegment15 = Phase3
GreenSegment16 = Phase3
GreenSegment17 = Phase3
GreenSegment18 = Phase3
GreenSegment19 = Phase3
GreenSegment20 = Phase4
GreenSegment21 = Phase4
GreenSegment22 = Phase4
GreenSegment23 = Phase4
GreenSegment24 = Phase4
GreenSegment25 = Phase4
GreenSegment26 = Phase5
GreenSegment27 = Phase5
GreenSegment28 = Phase5
GreenSegment29 = Phase5
GreenSegment30 = Phase5
GreenSegment31 = Phase6
GreenSegment32 = Phase6
GreenSegment34 = Phase6
GreenSegment35 = Phase6
'Vertical Red gradient
VerticalRedGradient:
RedSegment7 = Phase2
RedSegment8 = Phase2
RedSegment9 = Phase2
RedSegment10 = Phase2
RedSegment11 = Phase2
RedSegment12 = Phase2
RedSegment13 = Phase2
RedSegment14 = Phase3
RedSegment15 = Phase3
RedSegment17 = Phase3
RedSegment18 = Phase3
RedSegment19 = Phase3
RedSegment20 = Phase4
RedSegment21 = Phase4
RedSegment22 = Phase4
RedSegment23 = Phase4
RedSegment24 = Phase4
RedSegment26 = Phase5
RedSegment27 = Phase5
RedSegment28 = Phase5
RedSegment34 = Phase6
RedSegment35 = Phase6
'Vertical Red gradient Antiphase
VerticalRedAntiGradient:
RedSegment2 = Phase9
RedSegment3 = Phase9
RedSegment4 = Phase9
RedSegment5 = Phase9
RedSegment6 = Phase9
RedSegment7 = Phase10
RedSegment8 = Phase10
RedSegment9 = Phase10
RedSegment10 = Phase10
RedSegment11 = Phase10
RedSegment17 = Phase11
RedSegment18 = Phase11
RedSegment19 = Phase11
RedSegment20 = Phase12
RedSegment21 = Phase12
RedSegment22 = Phase12
RedSegment23 = Phase12
RedSegment24 = Phase12
RedSegment25 = Phase12
RedSegment26 = Phase13
RedSegment27 = Phase13
RedSegment28 = Phase13
RedSegment29 = Phase13
RedSegment30 = Phase13
RedSegment31 = Phase14
RedSegment32 = Phase14
RedSegment34 = Phase14
RedSegment35 = Phase14
'Monochromatic Green gradient
MonoGreenGradient:
GreenSegment7 = Phase1
GreenSegment8 = Phase1
GreenSegment9 = Phase1
GreenSegment10 = Phase1
GreenSegment11 = Phase1
GreenSegment12 = Phase1
GreenSegment13 = Phase1
GreenSegment14 = Phase1
GreenSegment25 = Phase1
GreenSegment28 = Phase1
GreenSegment29 = Phase1
GreenSegment30 = Phase1
GreenSegment31 = Phase1
GreenSegment32 = Phase1
GreenSegment33 = Phase1
GreenSegment34 = Phase1
GreenSegment35 = Phase1
'Monochromatic Red gradient
MonoRedGradient:
'Monochromatic Red gradient antiphase
MonoRedAntiGradient:
RedSegment7 = Phase9
RedSegment8 = Phase9
RedSegment9 = Phase9
RedSegment10 = Phase9
RedSegment15 = Phase9
RedSegment16 = Phase9
RedSegment17 = Phase9
RedSegment18 = Phase9
RedSegment19 = Phase9
RedSegment20 = Phase9
RedSegment21 = Phase9
RedSegment22 = Phase9
RedSegment23 = Phase9
RedSegment25 = Phase9
RedSegment26 = Phase9
RedSegment28 = Phase9
RedSegment29 = Phase9
RedSegment30 = Phase9
RedSegment31 = Phase9
RedSegment32 = Phase9
RedSegment33 = Phase9
'Button Interrupt Handler
ButtonInterrupt:
@ INT_DISABLE INT_INT ; disable Button interrupts
GOSUB TurnAllOff
GOSUB DisplayLoop
REPEAT
PAUSE 100
ButtonCounter = ButtonCounter + 1
UNTIL PushButton = 1 OR ButtonCounter = 10
IF ButtonCounter >= 10 THEN
StoredAnimationSpeed = StoredAnimationSpeed + 1
IF StoredAnimationSpeed > 12 THEN StoredAnimationSpeed = 0
WRITE 1, StoredAnimationSpeed
WRITE 0, AnimationStyle
ButtonCounter = 0
SpeedCounter = 255
@ INT_ENABLE INT_INT ; enable Button interrupts
@ INT_RETURN
And... I have missed BobK's comment. Using the 16F1847 would be the best solution... however I do not have PBP3 yet. I will keep that in mind though, as I may need to expand the project to drive 2 more LED boards from the same microcontroller (in order to keep the animation sequence in sync).
And when it comes to EEprom I did not say you should put it on the already made PCB. I said solder it straight onto the top of the PIC. If you have pins available on the PIC it just takes a steady hand and some time.
