hi everyone here, i'm newbie in pbp, i wrote a program so that when i shift 1 bit to left in portb, it will increase the pwm, while shift 1 bit to the right in portb will decrease the pwm. when i run my project, it seem doesnt run well, somemtimes it work, sometimes it's not. can you please let me know what problems i have? thank for your help.
my code shown below:
DEFINE CCP1_REG PORTC
DEFINE CCP1_BIT 2
DEFINE CCP2_REG PORTC
DEFINE CCP2_BIT 1
trisb = %11111111
trisc = %11110000
CCP1CON = %00001100
CCP2CON = %00001100
T2CON = %00000100
L VAR BYTE
M VAR BYTE
a var byte
b var byte
c var byte
d var byte
e var byte
f var byte
g var byte
h var byte
m = 80
l = 0
a = %00000001
b = %00000010
c = %00000100
d = %00001000
e = %00010000
f = %00100000
g = %01000000
h = %10000000
hpwm 1,0,1000
hpwm 2,0,1000
if portc.7 == 1 then 'selection button press, go to led
pause 850
goto LED
LED:
low portc.5
high portc.4
gosub LEDCOMPARE
pause 850
goto motor
goto LED
MOTOR:
low portc.4
high portc.5
GOSUB MOTORCOMPARE
pause 850
goto led
goto motor
LEDCOMPARE:
if (portb == a) then
if (portb == b) then
gosub ledincrease
if (portb == h) then
gosub leddecrease
if (portb == c) then
gosub ledincrease
gosub leddecrease
if (portb == d) then
gosub ledincrease
gosub leddecrease
if (portb == e) then
gosub ledincrease
gosub leddecrease
if (portb == f) then
gosub ledincrease
gosub leddecrease
if (portb == g) then
gosub ledincrease
gosub leddecrease
gosub ledincrease
gosub leddecrease
gosub ledincrease
gosub leddecrease
MOTORCOMPARE:
gosub MOTORincrease
gosub MOTORdecrease
gosub MOTORincrease
gosub MOTORdecrease
gosub MOTORincrease
gosub MOTORdecrease
gosub MOTORincrease
gosub MOTORdecrease
gosub MOTORincrease
gosub MOTORdecrease
gosub MOTORincrease
gosub MOTORdecrease
gosub MOTORincrease
gosub MOTORdecrease
gosub MOTORincrease
gosub MOTORdecrease
ledincrease:
high portc.4
l = l + 16
if (l >= 240 ) then
hpwm 1,255,1000
IF (L < 240) THEN
HPWM 1,L,1000
leddecrease:
high portc.4
l = l - 16
if (l <= 0) then
hpwm 1,0,1000 '
if (l > 0) then
hpwm 1,l,1000
motorincrease:
high portc.5
if (m >= 245) then
hpwm 2,255,1000
IF (m < 245) THEN
m = m + 11
HPWM 2,m,1000
motordecrease:
high portc.5
if (m <= 80) then
hpwm 2,0,1000
if (m > 80) then
m = m - 11
hpwm 2,m,1000
