Browned off by Brown Out [BOD]
Hi all,
I need some advice on BOD Brown Out Detect programming as I'm doing my head in....
Pic 12F683 locks up when Vdd voltage drops below 0.6Vdc and then returns => 1.5Vdc.
Obviously I need to use the built in BOD feature but I'm having issues getting it to work the way I want. Here are my issues:
1. If I set config fuse BOD = ON -> the device is continually in reset even when Vdd = 5V - basically a complete lock up.
2. If I set config fuse BOD = SBODEN and enable BOD within the program - the PIC will reset at the place the code executes the enable BOD command. However - the pic does indeed BOD reset when voltage BOD occures.
3. If I never enable BOD - then the program continues to work happily until a voltage BOD occures.
What I want is for the program to keep running until a BOD occurres (~2.0Vdc) - then reset.
Can someone see where I have gone wrong and point me in the right direction?
' SET FUSES
ASM ; PIC12F683
__CONFIG _MCLRE_OFF & _WDT_ON & _INTRC_OSC_NOCLKOUT & _BOD_SBODEN & _CPD_OFF &_PWRTE_ON
PAUSE 100 ' STARTUP DELAY
CMCON0 = 7 ' TURN ANALOG COMPARATOR MODE OFF
ANSEL = 0 ' MAKE ALL GPIOS INPUT ACCEPT GP2
TRISIO = $3B ' INT OSC 4MHZ
OSCCON = $61
SBOREN VAR PCON.4
POR VAR PCON.1
BOR VAR PCON.0
SBOREN = 0 ; BOR DISABLED
PAUSE 1000
SEROUT2 GPIO.2,188,["XXXXXXXXXXXX",13,10] ; CLEAR BUFFER
SEROUT2 GPIO.2,188,["RESET",13,10] ; ANNOUNCE PROGGY STARTED/RESET
MAIN:
if POR = 0 then ; POWER RESET OCCURRED
SEROUT2 GPIO.2,188,["POWER RESET OCCURRED",13,10]
POR = 1 ; CLEAR POR FLAG
if BOR = 0 then ; BROWN OUT OCCURRED
SEROUT2 GPIO.2,188,["BOR OCCURRED",13,10]
BOR = 1 ; CLEAR BOR FLAG
SEROUT2 GPIO.2,188,["Hello World!",13,10]
PAUSE 1000
SBOREN = 1 ' ENABLE BOR ; ENABLE BRWN OUT DETECT
GOTO MAIN
Re: Browned off by Brown Out [BOD]
This may or may not be relavent, buy try disabling the watchdog timer.
Hi, Squibcakes
Did you had a look to Datasheet $ 12.3.7 ??? I see some flags that have to be set or reset @ power up " by hand " .... :friendly_wink:
Acetronics
Hi, Squibcakes
Hi Ace,
I did actually RTFM - but I can't make heads or tails of this... what comes first the chicken or the egg when resets are envovled....maybe someone will throw me a bone.... ;)
