One of the suppliers that had quoted me for that switch with the red shaft has a model with 100gf to operate. The model I am testing now uses 330gf.
It would be easier to use that switch cause I...
Hall effect switch with small magnet or if there is magnetic field around solenoid coil that the hall effect device can sense
amgen Yesterday, 18:36So I have a need to override a pushbutton (from ON to OFF) and came up with this concept; a solenoid piggyback on a pushbutton switch with a 3D printed cap held by a strand of wire.
The sending device has the typical 18F4550 USB setup and it is set to "Define OSC 48". The receiving device is set to "DEFINE OSC 16".
rsocor01 - 24th April 2024, 19:56What is the clock of each PIC you use?
There is probably a little bit of both. I did a search in the forum, but couldn't find anyone having the same issue.
rsocor01 - 23rd April 2024, 23:22By lowering the baud rate you're now allowing device B (and SERIN2) twice the time to receive the bits and assemble the byte.
That's probably what's helping a lot more than any line noise issue.
Tumbleweed, I had very strong suspicions that the issues were in the communication lines. I changed the Baud rate from 19200 to 9600 and I haven't got anymore wrong data at the receiver. I remember...
rsocor01 - 22nd April 2024, 22:35Ioannis, yes I'm doing data validation checks all the time. The first byte of the array is always 174. If this condition is not met, then the reading is discarded.
rsocor01 - 22nd April 2024, 22:26
Re: New project - MSFS C++ USB interface
I've never used those types of switches before. Do you have a link?
Demon Today, 04:01I need a latching pushbutton switch to simulate these controls. They have to remain down when pressed ON, and pop out when...
