You might want to double check that you are setting the hardware communication correctly. I have used the code below to set the HSEROUT/HSERIN for the 18F4550. You might want to check the correct...
rsocor01 Today, 16:16Hi all,
Having issues transmitting numeric data out from the 18F26K83 using hserout. No problems with the software serout2, but for some reason all my numerical data is corrupted for hserout ie....
I have used hot glue before to secure a Dupont socket onto a header pin. But, even when I don't use the hot glue the connector never moves. Unless there is a lot of vibration, I don't think the glue...
rsocor01 Today, 13:47Have you ever used Loctite to secure a Dupont socket onto a header pin?
My initial plan was to do like many and use hotglue, but this particular situation requires a liquid that's less "thick",...
Sorry, I took a break for a few years and didn't see this post.
At first glance, your grid does look functionally like my leaning pyramid.
It's weird, your design looks more confusing to me. :D
Yup, you can pre-buy parts from suppliers by JLCPCB.
Pre-order the required components in advance to ensure sufficient components are ready anytime.
Place a PCBA order with confidence at any...
Regarding passives, like R's and C's, there are millions of brands and types available (but not on stock all the time).
It gives me headache everytime I have to do an assembly by JLCPCB...
But...
Not at the same time though. You have to watch the SOA curve and then you will realize that it is not so impressive as the numbers advertised by the manufacturer...
I was checking prices on JLCPCB for a MCP23017 circuit, and I noticed something when I entered their part numbers.
Did you know you can buy parts from other customers when JLCPCB doesn't have...
Re: hserout issues on the 18F26K83
I've set the hardware config totally manually from the datasheet and via PBP defines (suggested in the supplementary document PIC18FxxK42_notes) and many hybrids of the 2 methods.
rocket_troy Today, 16:41OSCFRQ =...
