mel PIC BASIC Pro
+ Post New Thread
Page 1 of 264 123451151101 ... LastLast
Threads 1 to 40 of 10557
Forum: mel PIC BASIC Pro
Discussion area for microEngineeringLabs Pic Basic Pro Compiler
  1. Sticky Thread Sticky: Important !
    Started by NavMicroSystems‎, - 14th February 2005 19:46
    - 14th February 2005, 19:46 Go to last post
  1. Question Direct Register Access not recognized
    Started by PCzar3‎, Today 00:58
    Today, 19:02 Go to last post
  2. PBP and IDE/programmer
    Started by robertg‎, - 14th June 2024 19:24
    Today, 15:02 Go to last post
  3. hserout issues on the 18F26K83
    Started by rocket_troy‎, - 13th May 2024 14:56
    - 14th June 2024, 12:34 Go to last post
  4. Replacing 16F628A with 16F1827 - need help, please !
    Started by fratello‎, - 7th June 2024 08:05
    - 9th June 2024, 18:56 Go to last post
  5. trick with Serin
    Started by Marcick‎, - 20th May 2024 12:50
    - 20th May 2024, 20:30 Go to last post
  6. SERIN2 Receiving Wrong Data
    Started by rsocor01‎, - 20th April 2024 01:21
    - 4th May 2024, 20:31 Go to last post
  7. Serin Not Recognizing Qualifier From Another PIC
    Started by JESmitter‎, - 17th April 2024 00:38
    - 19th April 2024, 14:42 Go to last post
  8. 12F683 ADC problems
    Started by andywpg‎, - 5th April 2024 16:46
    - 15th April 2024, 16:34 Go to last post
  9. Problem above address 19720h
    Started by Marcick‎, - 4th April 2024 13:09
    - 4th April 2024, 13:09 Go to last post
  10. How to measure how long I pressed a button ?
    Started by fratello‎, - 27th March 2024 16:52
    - 2nd April 2024, 08:31 Go to last post
  11. I2C Communication between PIC18F4550 and AS5600
    Started by soren7‎, - 12th March 2024 17:14
    - 13th March 2024, 14:20 Go to last post
  12. Blinker for 16F18446 - OSC settings and PORT addressing
    Started by flotulopex‎, - 10th February 2024 08:45
    - 10th February 2024, 13:40 Go to last post
  13. MCP3301 A/D converter SPI reading
    Started by flotulopex‎, - 1st February 2024 21:15
    - 10th February 2024, 12:07 Go to last post
  14. SSD1306 Inverse screen example?
    Started by wjsmarine‎, - 27th January 2024 05:21
    - 28th January 2024, 04:20 Go to last post
  15. PIC16F886 Pulldown inputs
    Started by pescador‎, - 9th January 2024 19:53
    - 10th January 2024, 21:15 Go to last post
  16. Avoiding too many GOSUBs, possible?
    Started by CuriousOne‎, - 22nd December 2023 07:09
    - 26th December 2023, 23:50 Go to last post
  17. Using MPLABX 5.35 Assembler without PbPro
    Started by retepsnikrep‎, - 22nd December 2023 15:09
    - 23rd December 2023, 14:39 Go to last post
  18. SSD1306 OLED (72x40) I2C display from scratch
    Started by flotulopex‎, - 13th November 2023 17:04
    2 Pages
    1 2
    - 16th December 2023, 12:29 Go to last post
    - 15th December 2023, 05:46 Go to last post
  19. NEC IR decoding issues (and another thread is closed)
    Started by CuriousOne‎, - 10th December 2023 09:18
    - 10th December 2023, 17:46 Go to last post
  20. Ramp up down? Code ideas.
    Started by retepsnikrep‎, - 24th November 2023 09:10
    - 25th November 2023, 06:43 Go to last post
  21. Quadcopter on an 18F25K20
    Started by achilles03‎, - 2nd September 2023 21:00
    - 24th November 2023, 22:15 Go to last post
    - 5th November 2023, 16:26 Go to last post
  22. PCF8575 Does not work with my code....
    Started by CuriousOne‎, - 21st October 2023 19:22
    - 1st November 2023, 04:57 Go to last post
  23. Depending on value, SOUND statement leaves port output high
    Started by CuriousOne‎, - 4th October 2023 05:19
    - 5th October 2023, 12:05 Go to last post
  24. Can't find my .hex file - timestamps confusing?
    Started by Gerald‎, - 13th September 2023 07:17
    - 26th September 2023, 07:11 Go to last post
  25. DT Ints not working on 16F18426
    Started by wjsmarine‎, - 27th August 2023 10:16
    - 20th September 2023, 14:28 Go to last post
  26. Using as many internal peripherals as possible.
    Started by louislouis‎, - 29th August 2023 17:58
    - 2nd September 2023, 12:27 Go to last post
  27. 18F26K80 Serial setting sanity check and 4xPLL.
    Started by retepsnikrep‎, - 27th July 2022 16:11
    - 20th August 2023, 16:05 Go to last post
  28. 18F26K80 Code Optimisation.
    Started by retepsnikrep‎, - 14th August 2023 14:02
    - 16th August 2023, 17:38 Go to last post
    - 13th August 2023, 17:29 Go to last post
  29. SHIFTOUT with PIC12F675?
    Started by zorgloub‎, - 20th July 2023 14:32
    - 1st August 2023, 17:12 Go to last post
  30. DFPlayer MP3 Module and Reading #files in several folders
    Started by Atom058‎, - 22nd July 2023 21:34
    - 22nd July 2023, 21:34 Go to last post
    - 14th July 2023, 16:25 Go to last post
  31. PAUSE for a variable time? Using MAX and MIN
    Started by Gerald‎, - 29th June 2023 14:20
    - 30th June 2023, 07:05 Go to last post
  32. Which is most PBP-Friendly external ADC?
    Started by CuriousOne‎, - 17th June 2023 08:04
    - 24th June 2023, 17:17 Go to last post
    - 9th June 2023, 03:23 Go to last post
  33. Leaves the mainloop???
    Started by pescador‎, - 31st May 2023 20:22
    2 Pages
    1 2
    - 4th June 2023, 20:01 Go to last post
  34. Using same button for entering/exiting some part of code?
    Started by CuriousOne‎, - 21st March 2023 12:11
    - 28th May 2023, 21:43 Go to last post
    - 24th May 2023, 07:23 Go to last post
Forum Information and Options
Users Browsing this Forum
There are currently 199 users browsing this forum. (1 members & 198 guests)
  1. PCzar3
Thread Display Options
Use this control to limit the display of threads to those newer than the specified time frame.
Allows you to choose the data by which the thread list will be sorted.
Order threads in...
Note: when sorting by date, 'descending order' will show the newest results first.
Icon Legend
Contains unread posts
Contains no unread posts
More than 15 replies or 50 views
Hot thread with unread posts
Hot thread with no unread posts
Thread is closed
Thread Contains a Message Written By You
You have posted in this thread
