mel PIC BASIC Pro
+ Post New Thread
Page 1 of 265 123451151101 ... LastLast
Threads 1 to 40 of 10570
Forum: mel PIC BASIC Pro
Discussion area for microEngineeringLabs Pic Basic Pro Compiler
  1. Sticky Thread Sticky: Important !
    Started by NavMicroSystems‎, - 14th February 2005 19:46
    - 14th February 2005, 19:46 Go to last post
    Today, 14:04 Go to last post
  1. Can't get IOC on pin change working
    Started by huntrashm‎, - 11th September 2024 03:08
    - 12th September 2024, 23:31 Go to last post
  2. Variable changing mid-code in 16F883?
    Started by achilles03‎, - 4th September 2024 04:32
    - 4th September 2024, 12:53 Go to last post
  3. HSerin waits indefinetely
    Started by robertg‎, - 19th August 2024 09:07
    - 19th August 2024, 12:55 Go to last post
  4. Clean code for DST calculation based on GPS data
    Started by flotulopex‎, - 17th August 2024 16:40
    - 18th August 2024, 07:44 Go to last post
  5. This simple code fragment crashes and restarts MCU!
    Started by CuriousOne‎, - 16th August 2024 16:32
    - 17th August 2024, 03:02 Go to last post
  6. 12f509 and DS18B20
    Started by robertg‎, - 8th August 2024 09:24
    - 13th August 2024, 00:35 Go to last post
  7. ICD, ICSP and Picbasic Pro
    Started by mwhatley‎, - 24th September 2005 16:27
    - 8th August 2024, 20:42 Go to last post
  8. I2C communication with BMI088 IMU?
    Started by achilles03‎, - 4th August 2024 19:42
    - 5th August 2024, 10:05 Go to last post
  9. I2C Communication between PIC18F4550 and AS5600
    Started by soren7‎, - 12th March 2024 17:14
    - 5th August 2024, 10:00 Go to last post
  10. Addressing multiple PORTs using one Variable
    Started by flotulopex‎, - 23rd July 2024 17:06
    - 4th August 2024, 18:01 Go to last post
  11. Blink that LED with a 18F1330
    Started by flotulopex‎, - 27th July 2024 19:03
    - 28th July 2024, 08:00 Go to last post
  12. Optimizing memory usage for ARRAYWRITE statement?
    Started by CuriousOne‎, - 25th July 2024 19:14
    - 26th July 2024, 04:38 Go to last post
  13. How do I check my crystal's operation/configuration?
    Started by flotulopex‎, - 21st July 2024 19:42
    - 23rd July 2024, 16:40 Go to last post
  14. Trouble reading GPS from "NEO-6" module
    Started by CuriousOne‎, - 14th July 2024 19:42
    - 21st July 2024, 22:38 Go to last post
  15. PBP and IDE/programmer
    Started by robertg‎, - 14th June 2024 19:24
    - 21st June 2024, 05:31 Go to last post
  16. Question Direct Register Access not recognized
    Started by PCzar3‎, - 18th June 2024 00:58
    - 18th June 2024, 19:02 Go to last post
  17. hserout issues on the 18F26K83
    Started by rocket_troy‎, - 13th May 2024 14:56
    - 14th June 2024, 12:34 Go to last post
  18. Replacing 16F628A with 16F1827 - need help, please !
    Started by fratello‎, - 7th June 2024 08:05
    - 9th June 2024, 18:56 Go to last post
  19. trick with Serin
    Started by Marcick‎, - 20th May 2024 12:50
    - 20th May 2024, 20:30 Go to last post
  20. SERIN2 Receiving Wrong Data
    Started by rsocor01‎, - 20th April 2024 01:21
    - 4th May 2024, 20:31 Go to last post
  21. Serin Not Recognizing Qualifier From Another PIC
    Started by JESmitter‎, - 17th April 2024 00:38
    - 19th April 2024, 14:42 Go to last post
  22. 12F683 ADC problems
    Started by andywpg‎, - 5th April 2024 16:46
    - 15th April 2024, 16:34 Go to last post
  23. Problem above address 19720h
    Started by Marcick‎, - 4th April 2024 13:09
    - 4th April 2024, 13:09 Go to last post
  24. How to measure how long I pressed a button ?
    Started by fratello‎, - 27th March 2024 16:52
    - 2nd April 2024, 08:31 Go to last post
  25. Blinker for 16F18446 - OSC settings and PORT addressing
    Started by flotulopex‎, - 10th February 2024 08:45
    - 10th February 2024, 13:40 Go to last post
  26. MCP3301 A/D converter SPI reading
    Started by flotulopex‎, - 1st February 2024 21:15
    - 10th February 2024, 12:07 Go to last post
  27. SSD1306 Inverse screen example?
    Started by wjsmarine‎, - 27th January 2024 05:21
    - 28th January 2024, 04:20 Go to last post
  28. PIC16F886 Pulldown inputs
    Started by pescador‎, - 9th January 2024 19:53
    - 10th January 2024, 21:15 Go to last post
  29. Avoiding too many GOSUBs, possible?
    Started by CuriousOne‎, - 22nd December 2023 07:09
    - 26th December 2023, 23:50 Go to last post
  30. Using MPLABX 5.35 Assembler without PbPro
    Started by retepsnikrep‎, - 22nd December 2023 15:09
    - 23rd December 2023, 14:39 Go to last post
  31. SSD1306 OLED (72x40) I2C display from scratch
    Started by flotulopex‎, - 13th November 2023 17:04
    2 Pages
    1 2
    - 16th December 2023, 12:29 Go to last post
    - 15th December 2023, 05:46 Go to last post
  32. NEC IR decoding issues (and another thread is closed)
    Started by CuriousOne‎, - 10th December 2023 09:18
    - 10th December 2023, 17:46 Go to last post
  33. Ramp up down? Code ideas.
    Started by retepsnikrep‎, - 24th November 2023 09:10
    - 25th November 2023, 06:43 Go to last post
  34. Quadcopter on an 18F25K20
    Started by achilles03‎, - 2nd September 2023 21:00
    - 24th November 2023, 22:15 Go to last post
    - 5th November 2023, 16:26 Go to last post
  35. PCF8575 Does not work with my code....
    Started by CuriousOne‎, - 21st October 2023 19:22
    - 1st November 2023, 04:57 Go to last post
  36. Depending on value, SOUND statement leaves port output high
    Started by CuriousOne‎, - 4th October 2023 05:19
    - 5th October 2023, 12:05 Go to last post
  37. Can't find my .hex file - timestamps confusing?
    Started by Gerald‎, - 13th September 2023 07:17
    - 26th September 2023, 07:11 Go to last post
Forum Information and Options
Users Browsing this Forum
There are currently 433 users browsing this forum. (0 members & 433 guests)
Thread Display Options
Use this control to limit the display of threads to those newer than the specified time frame.
Allows you to choose the data by which the thread list will be sorted.
Order threads in...
Note: when sorting by date, 'descending order' will show the newest results first.
Icon Legend
Contains unread posts
Contains no unread posts
More than 15 replies or 50 views
Hot thread with unread posts
Hot thread with no unread posts
Thread is closed
Thread Contains a Message Written By You
You have posted in this thread
