I start to play with one of this cheap 4 digit 7 segment display. The display is driven by two 74HC595 which one is for segments and the other is for common cathodes (digits).
Here is the schematic:
I writed a simple code using Darrel's interrupts. Code multiplexing the digits using TMR1 interrupt.
It works OK, but I think that code is not as elegant. It looks rough, because I'm not a skilled programmer.
Can someone explain to me a better way to do this task?
Here is my code:
'**************************************************************** '* Name : 4 bit 7 segment display * '* Author : LouisLouis * '* Notice : Copyright (c) 2018 * '* : All Rights Reserved * '* Date : 18. 2. 2018 * '* Version : 1.0 * '* Notes : * '* MCU : PIC 12F1840 * '**************************************************************** #CONFIG __config _CONFIG1, _FOSC_INTOSC & _WDTE_OFF & _PWRTE_ON & _MCLRE_OFF & _CP_OFF & _CPD_OFF & _BOREN_ON & _CLKOUTEN_OFF & _IESO_ON & _FCMEN_ON __config _CONFIG2, _WRT_OFF & _PLLEN_ON & _STVREN_ON & _BORV_19 & _LVP_OFF #ENDCONFIG DEFINE OSC 32 ; Use internal clock OSCCON = 110000 CLKRCON = 0 Include "modedefs.bas" INCLUDE "DT_INTS-14.bas" ; Base Interrupt System INCLUDE "ReEnterPBP.bas" ; Include if using PBP interrupts TRISA = 0000 ANSELA = 00 OPTION_REG.7=0 ; Enable internal pull-ups LPIN var porta.2 ; Latch DPIN var porta.4 ; Data CPIN var porta.5 ; Clock segment var byte value var word place var byte[4] ones var word tens var word hundreds var word thousands var word ASM INT_LIST macro ; IntSource, Label, Type, ResetFlag? INT_Handler TMR1_INT, _DISP, PBP, yes endm INT_CREATE ; Creates the interrupt processor ENDASM @ INT_ENABLE TMR1_INT ; enable Timer 1 interrupts T1CON = $1 ;---[simple counter 0 - to 9999]------------------------------------------------ Main: for value = 0 to 9999 pause 100 next value value = 0 GOTO Main ;---[TMR1 - interrupt handler]-------------------------------------------------- DISP: T1CON.0 = 0 ; stop timer TMR1H = 111100 TMR1L = 011111 T1CON.0 = 1 ; restart timer ;---[extract ones and show]----------------------------------------------------- ones = value//10 lookup ones, [000000,111001,100100,110000,011001,010010,000010,111000,000000,010000],segment LOW LPIN Shiftout DPIN, CPIN, MSBFIRST,[segment,01] high lpin pause 4 ;---[extract tens and show]----------------------------------------------------- tens = value/10 tens = tens//10 lookup tens, [000000,111001,100100,110000,011001,010010,000010,111000,000000,010000],segment LOW LPIN Shiftout DPIN, CPIN, MSBFIRST,[segment,10] high lpin pause 4 ;---[extract hundreds and show]------------------------------------------------- hundreds = value/100 hundreds = hundreds//10 lookup hundreds, [000000,111001,100100,110000,011001,010010,000010,111000,000000,010000],segment LOW LPIN Shiftout DPIN, CPIN, MSBFIRST,[segment,00] high lpin pause 4 ;---[extract thousands and show]------------------------------------------------ thousands = value/1000 place = 00 lookup thousands, [000000,111001,100100,110000,011001,010010,000010,111000,000000,010000,001000],segment LOW LPIN Shiftout DPIN, CPIN, MSBFIRST,[segment,00] high lpin @ INT_RETURN
Re: New project - MSFS C++ USB interface
One of the suppliers that had quoted me for that switch with the red shaft has a model with 100gf to operate. The model I am testing now uses 330gf.
Demon Today, 03:51It would be easier to use that switch cause I...
