Darrel's oversampling code and info can be found here: http://www.darreltaylor.com/DT_Analog/
Attached is his file that takes multiple samples from the A/D converter, and can "oversample" from 10 to 16 bits resolution. It is pretty slick, as it can make a 16 bit A/D converter out of a $1.50 PIC12F683.
'**************************************************************** '* Name : UNTITLED.BAS * '* Author : Walter Dunckel * '* Notice : Copyright (c) 2009 Scale Robotics Inc. * '* : All Rights Reserved * '* Date : 6/3/2009 * '* Version : 1.1 * '* Notes : * '* : * '**************************************************************** @ __config _INTRC_OSC_NOCLKOUT & _WDT_OFF & _MCLRE_OFF & _CP_OFF DEFINE OSC 8 DEFINE ADC_BITS 10 '10 BIT A/D CONVERSION RESULT DEFINE ADC_CLOCK 2 'INTERNAL A/D RC CLOCK DEFINE ADC_SAMPLEUS 5 'SET SAMPLE TIME IN MICROSECONDS INTCON = %10001000 'internal oscillator OSCCON = %01110000 'set for 8mhz internal CMCON0 = 7 'TURN COMPARITORS OFF TRISIO = %010000 'Set GSIO 4 INPUT, others to OUTPUT ANSEL = %01011000 ' ADCON0.7 = 1 'Right Justify for 10-bit ADCON0 = %10001101 'analog 3 channel INCLUDE "DT_Analog.pbp" ; DT's 16-bit Analog Module PIR1.0 = 0 dEFINE DEBUG_REG GPIO dEFINE DEBUG_BIT 0 dEFINE DEBUGIN_BIT 1 DEFINE DEBUG_BAUD 38400 DEFINE DEBUG_MODE 0 ALTresult var word 'lookup table output tempALT var word 'base altitude of lookup from table ADtemp var byte 'lookup table input ALTdifference var word 'difference of two nearby altitudes finalALT var word 'final calculated altitude in feet LeftShift var byte 'shifts ADvalue to match lookup table tempword var word metric var bit symbol i = ADtemp 'share byte symbol LEDcount = tempALT.byte0 symbol pulses = tempALT.byte1 'share byte 'test var byte metric = 0 'specify metric =1 for metric & 0 for feet ADbits = 16 'specify oversampling bits (10 to 16) ADchan = 3 'ANchannel your MPX4115a is on GPIO.5 = 0 LED var GPIO.5 Main: led = 0 GOSUB GetADC ' Get A/D value leftshift = 16 - ADbits ' calculate number of shifts required ADvalue = ADvalue << leftshift 'shift to match 16 bit lookup table ADtemp = ADvalue/1000 - 15 ' get to right value for lookup gosub lookmeup tempALT = ALTresult 'save first result for use in math ADtemp = ADtemp - 1 'run second lookup for alt difference calc gosub lookmeup ALTdifference = ALTresult - tempALT 'get difference in nearby alt 'use difference to calculate slope & adjust altitude accordingly finalalt = (ADvalue//1000)* altdifference tempword = div32 100 finalalt = tempword/10 if tempword//10 >= 5 then finalalt = finalalt + 1 'round remainder finalALT = tempalt - finalALT if metric = 1 then finalALT = (finalalt * 25)/82 'feet to meters debug "ALT ",DEC finalALT,13,10 gosub LEDout GOTO Main: End lookmeup: lookup2 ADtemp,[25989,24934,23921,22942,21995,21078,20190,19327,18489,17673,_ 16879,16106,15351,14615,13896,13194,12507,11834,11176,10532,9900,9280,8672,_ 8076,7490,6915,6349,5794,5247,4710,4181,3660,3148,2643,2145,1655,1172,696,_ 226],ALTresult return LEDout: for i = 4 to 0 step -1 ledcount = finalalt dig i if ledcount > 0 then gosub LEDpulse else led = 1 pause 4 led = 0 pause 596 endif next i pause 1000 return LEDpulse: for pulses = 1 to ledcount led = 1 pause 200 led = 0 pause 400 next pulses pause 600 return end
Re: New project - MSFS C++ USB interface
Hall effect switch with small magnet or if there is magnetic field around solenoid coil that the hall effect device can sense
amgen Today, 18:36
